Soocom1
- Joined
- Feb 27, 2006
- Messages
- 3,253
- Reaction score
- 1,490
- Can others edit my Photos
- Photos NOT OK to edit
which is WHY they are called CROPPED sensors.I'm glad you agree with me. But the registration distance is not really to do with the size of the image circle - Nikon APS and FF SLRs have the same registration distance - most (but not all) DX lenses have a smaller image circle than is needed for FX, but with the same registration distance!
Mirrorless cameras have a shorter registration distance because there is no need for a mirror box. Crudely, Nikon could make a lens for a Z6 by taking a D850 lens and gluing a bit of aluminium to it, and it would work exactly as it did on the D850. Indeed, that what the FTZ is - a hollow aluminium tube with some electrical contacts. Fitting a native Z6 lens on to a D850 is just as easy in theory - all you need is a hacksaw. However, one big advantage of the mirrorless with its short register distance is that short focal-length lenses don't need as many compromises inherent in retrofocus designs. But yes, I could remove the mirror box from a D850 with a hacksaw and make a Z6 lens work on it - but it seems a rather expensive project.
OK...
But enough of theory - can it be done? Yes. I make very crude lenses, and my single-element 72mm lens works on ALL of my (IL) cameras - NEX, Z6, D5100, Petri - completely ignorant of which camera it was designed for (because in reality it's a magnifying glass and a variety of Pringles tubes).
I can place a magnifying glass on a camera and make it work..
That's not the point.
And if you want a really, really simple proof of what I say, make a pinhole, put it on a camera, and take a picture. Add some extension tubes, and take the same picture. The 'focal length' will have changed, but the two pictures will have exactly the same perspective, albeit that the first one will show a bit more of the image.
The dynamics of lens construction and camera design has specific advantages.
the reg. distance is based again on the image circle aspect. There are adapters to fit 35mm lenses on Med. Format mirrorless. It can create an image circle and work, but in most aspects has no infinity.
But the aspect here is back to the OP.
The portrait lens of 85mm in this argument is based on 35mm camera design. (mirrorless or not.)
85mm has specific design aspects that make it more favorable (as pointed out in another post) mostly to european and Western tastes.
This includes typ. (though not always) a larger and faster lens, a narrower FoVV and less distortion int he sweet spot but allowing for a larger amount of light.
Original 85mm lenses from the 1960's have smaller elements and in some cases not as a dynamic range effect. this is why they are preferred. it makes for a nice compromise.
Having discovered the 135mm by accident in the 1980's I came to find the overall image quality heads and tails above a standard 50 or even 58mm (Rokkor lens) that I had inherited from the ol' man.
The problem there is the distance needed to make a clean image. More distance, narrower FoV and a smaller sweet spot translated to a good portrait but alot of lighting adjustments.
Again, why I prefer Med. Format.
