2WheelPhoto
- Joined
- Apr 14, 2011
- Messages
- 6,844
- Reaction score
- 996
- Location
- Tampa
- Can others edit my Photos
- Photos OK to edit
shutter speed will have a big impact on ambient, aperture on flash
I'm just learning off camera flash (OCF) and found out that the AB800 will fire when it "see's" another flash. If you have another flash with OCF capabilities like Pocket Wizard Flex TT5's you can set the flash to go off in a totally different direction and up your shutter speed to whatever will "kill" the light somewhat.
I fail to see the relevance of this to the OP's issue. Using another light as an optical slave will create more light and not help with the issue of already having too much light.
hmmm thought using a faster shutter speed would kill some of that light. the other light could be dialed down to almost nothing. Maybe I'm wrong. Like I said, I'm just starting off camera flash. My bad!
Like Derrel mentioned above, Gelling the lights would be best with neutral filters. The A800s have to much muscle even on lowest output for shooting with wide apertures. Moving the lights farther back would reduce the "softness" of the light significantly.. and is probably not a good idea.
