Thanks for replies. This has been a great lesson.
NOW... put the camera into "spot" metering mode. Meter the performers face (not their clothing. not their guitar.) Find an ISO that provides a correct exposure of the skin on their face without have to adjust the f-stop or shutter speed any further.
What's the procedure to find an ISO that provides a correct exposure? Use the Histogram as guidance (or reference)? Or is there a camera function that will help you (or is more essential) to find the correct exposure? (Then the next step is obviously to set the ISO correctly.) Guess I need to brush-up on ISO and exposure guides.
When you use the camera's built-in meter, it's only going to tell you if it thinks your "current" settings will be under-exposed, correctly exposed, or over-exposed. It wont provide specific values like a hand-held meter (but even a hand-held meter works a bit like an algebra solver... you fill in a few values that you'd like to control and the meter tells you what to set the remaining value to in order to get a correct exposure.)
What are the focal ratio options for the lens(es) you own? Can you shoot at f/2.8? How about f/2?
I have two different lenses that usually get used for concerts. One is a 70-200mm f/2.8, the other is a 135mm f/2.
Based on my experience, a typical concert exposure might be f/2.8, 1/60th, and ISO 3200. But this is really based on the lighting at the the time. If I'm using the f/2 lens then I might be able to increase to 1/125th. If the lighting is better than average, I can drop the ISO down to 1600. I'm just working the meter off the performer's face. The lens wont let me open the f-stop any further (I'm at the limit) so this leaves me with shutter speed and ISO options. The image stabilization on the lens will let me get down to about 1/60th for a hand-held shot. If I can brace the lens AND if I'm really watching the performer and waiting for the right moments, I might be able to get a shot at 1/30th (but clearly there's an element of luck at work here to go that slow.) That leaves ISO. I prefer to keep it as low as possibility, but given the choice between a low ISO shot that forces a shutter speed that was too slow and ends up blurry OR a higher ISO resulting in a sharp image which is grainy, I'll take the grainy shot.
Here's f/2, 1/60th, and ISO 6400. While it probably looks ok in this web-sized image, the full-size version shows that it has quite a bit of noise. Notice the blur in his hand as he plays the guitar... his hand is moving too quickly for the 1/60th shutter.
Chris Koza in Concert by
Tim Campbell1, on Flickr
Here's one where I got a bit luckier. This shot (of Jon McLaughlin) at f/2.8, ISO is down to 3200, and yet I was able to get the shutter speed up to 1/500th because of the lighting (Usually I would have dropped the ISO down to 1600 and cut the shutter speed since I really don't need 1/500th for these shots.)
IMG_4743 by
In these examples, I arrive at the exposure by setting the f-stop to what the lens will allow, setting the shutter speed to the minimum I know I'll need, then setting the ISO to whatever I can get away with to balance the exposure. Concert lighting can vary quickly. The rapidly varying lighting is all part of the "show".
