bigtwinky
- Joined
- Oct 6, 2008
- Messages
- 4,821
- Reaction score
- 286
- Location
- Montreal
- Can others edit my Photos
- Photos NOT OK to edit
When I eat in a restaurant I don't care what brand stove they use as long as the food's good.![]()
I also don't allow the waitress to dictate what I will be eating. If I want a club sandwhich, but they already have 6 orders of that, I ain't going to eat the smoked meat, ya know?
You will probably end up getting alot of that gear. Impact lighting stuff is low end, but decent quality. Good for beginners. But you dont need all that now, not when you go through the learning process.
The T2i is a great camera. Just as the 60D and 7D or the D90 and D7000. If you want something that is GREAT, then its out of your budget (D700 or 5D2). The thing is, you will probably end up getting the GREAT body down the road. So don't beat yourself over which one to get now. If you don't know any better, they will all seem the same. What IS important is ergonomics and feel, which you can never get on the phone. You need to be comfortable with the layout of the buttons and grip. Granted the T2i has a different button layout than then 7D, but the general way the camera works is the same.
As for lenses, I would not get the 17-85. Bad recommendation. Its not a horrible lens, but if you are aiming for portraits, I'd look at a 50mm 1.4 or 1.8 to start. I would stay away from the EF-S lenses, as these only work on crop body cameras. If the salesman was being thorough, they would ask if you plan on upgrading to full frame cameras (which it seems like you do) in which case the 17-85 will NOT work. Bad recommendation. Look for EF lenses in the Canon lineup, not EF-S, if you want to later use better bodies.
For the lighting needs, getting a flash is a must. The 430EX II does not have any ports in it. If you are using the Canon infrared to trigger these (which works good), you are limited to line of sight. If you want to use radio triggers (which is IMO the best way to get the flash off camera) you need a universal translator for the flash. If you really want to learn portrait lighting, you should work in full manual. TTL is great, but learn from the ground up.
I have the 430EX II, its a good little flash for running and gunning, but nothing more than a slave flash when used with infrared. You either need to look at the 580EX II (more expensive) or look into third party flashes such as the Vivitar 285HV or the Lumopro LP160. Both under $200. Don't work in automatic with your camera, but great for manual off camera lighting. Or get a used Nikon flash... if you are doing off camera, you can mix brands. Might have colour balance issues though.
All that is just the same as for Nikon.
I did the mistake of first buying cheap lenses, which I had to sell to upgrade. Should of saved to get better lenses off the bat.
