KUZMICH PHOTOGRAPHY
  • Thread Starter Thread Starter dimakuzmich
  • Start date Start date
:popcorn:
btw... I think that image is tilted.
:popcorn:
what does that mean
It means that the horizon is tilted.
Furthermore, no one partaking in photographic arts, specifically portraiture, should ever claim that "the background doesn't matter." If you're not considering all aspects of the photograph from lighting, composition, subject matter, and background, you're far from a professional.
I'm sorry, the subject does not "make" the photo. The water is now unnaturally red, there's a dark void on the left side of the frame. The subject is almost dead center within the frame.
Also, having a 5D Mark II and 24-70 f/2.8 doesn't make you a professional either.
i got the 24-70mm 2.8, 85mm 1.2, 50mm 1.4, like i said the background does not matter in this picture, if its nature or a beautiful sky then i capture that moment ;)
That may be true, but if you add a couple of primes as well and can make photos red in photoshop then you're an insta-pro
and plus who said its red, its fall orange, look at the first picture the water is green cause of the reflection and alot of things are green in there, then if you know a program called "photoshop" (probably not) you can change the hue of the green to orange and all green changes into orange, then add a vignette. DONE
...However, you've also done something funky with the top of her hair...
It was a quick fixing, just a sketch in 2 minutes to show an idea. Being my picture, I should had edited it carefully.
It's time to upgrade to 5DM3. :D
Can you please elaborate on these complicated techniques? How does I make colours look unrealistic? Vignette? Is that some kind of salad dressing?
