Lens for Canon 5D Mark II
MBPhotography
Miami, FL
I currently have the 50mm 1.4 for my Canon but I am looking for something else since the 50mm is not very versatile. I am doing newborn and child photography professionally and would like a versatile yet professional quality lens.
I am also open to suggestions on your favorite lenses for the 5D Mark II.
Thank you!
www.MonicaBlancoPhotography.com
24-70L seems like the best idea, but for portraits and such you want a 80mm or longer. I don't know much of canon's lenses but maybe this?Canon 85mm f/1.2 L II
If we're talking 85's, then even the 85 1.8 would be outstanding on a 5D. IMO, it's a much better lens optically than her current 50 1.4. It's also $400 vs. $2000, and delivers "L like" IQ.
I suggested the 24-70 because she said versatility. For me, versatility = zoom.
24-70 f/2.8-L or 24-105 f/4 L IS would be my suggestions. Even an older 28-70mm f/2.8-L Canon lens. Like subscuck above, to me, versatility means a top-grade zoom lens.
Canon 24-70mm f/2.8 L.
Amazing glass. My favorite lens if I had to pick one.
Canon 70-200 f/2.8 IS L II
Amazing. The previous Version I is fantastic too.
Canon 135 f/2 L
Great for portraits. But not as versatile as the 70-200.
Thank you!
By the "50mm lens is not very versatile", you mean the "50mm lens is one of the most versatile and best walkaround lens on a full frame body" right?
Thank you!
An incredibly subjective statement. I find 50 (equiv) fairly useless - less than 1% of my keepers at at ~50 (even if I call it 40-60 it wouldn't be more than ~2%).
Thank you!
You are not on a full frame body.
Read where I wrote 50 (equiv).
Two different beasts. Not really able to compare the two. Looking at your lens selection, unless you have a 35mm, you don't have anything that's "equivalent" to a 50mm FoV. And if you did have a 35mm, it wouldn't give you images that look similar to 50mm on a full frame body. To frame a shot the same way on an APS-C vs a FF sensor would render bokeh completely different, as well as have a different degree of corner sharpness. I think you'd find that the majority of people shoot with a 50mm a lot (perhaps more than any other focal length, but this isn't true for everyone). 50mm is IMO too limited of a field of view indoors when used on an APS-C camera, but then again, this depends on the size of the room as well.
Because the 18-55 doesn't pass past 31.25 right?
And of course there is a difference in rendering (~1.5ish (cant remember the exact) stops more DoF (to have same framing at the same f-stop) etc etc) but the point is on you making a blanket statement on the usefulness of a focal length just to contradict the position held by OP.
And to get the thread back on track; 85 f/1.8, 100 f/2 and 135 f/2 are all lenses to consider if you want something a little faster than 2.8 at the expense of zoom.
Two different beasts. Not really able to compare the two. Looking at your lens selection, unless you have a 35mm, you don't have anything that's "equivalent" to a 50mm FoV. And if you did have a 35mm, it wouldn't give you images that look similar to 50mm on a full frame body. To frame a shot the same way on an APS-C vs a FF sensor would render bokeh completely different, as well as have a different degree of corner sharpness. I think you'd find that the majority of people shoot with a 50mm a lot (perhaps more than any other focal length, but this isn't true for everyone). Using a 50mm lens is IMO too limited of a field of view indoors when used on an APS-C camera, but then again, this depends on the size of the room as well.
At 31.25mm the EF-S 18-55mm has a max aperture of f/4.5. That's 3 1/3 stops. You really have no frame of reference. You have nothing that performs like a fast prime in that focal range.
