Lens help?? :)
JaimeGibb
Occoquan, VA
What's the best kind of lens to use for photographing people?? I have a Cannon 20D with the the basic 18-55mm lens. I would really like to invest in another, more high-tech lens, but I'm not sure what to get!!! Anyone have any suggestions? Thanks!!
~Jaime
i have the same camera. the lens i have is a 17-85ef-s USM lens. it's made for the smaller sensor cameras so it will be real wide angle and it also goes up to 85 which gives you a tad bit of telephoto use. it's a great lens. it also has image stabilize. i think it's great. it's not a big lens so you don't have to worry about weight being an issue.
Generally if you are talking about portraits, prime lenses are highly recommended. I would pick up a nice 50mm, something around 75mm and one around 100. Prime lenses are typically well constructed, have great optical qualities and are generally pretty "fast" lenses as well. I use my 50mm quite a bit for portraits, and recently picked up a 70mm as well. With a cropped sensor that gives me a conversion of a 75mm lens and a 105mm, both of which are a good length for portraits.
Canon 50mm f/1.8 or f/1.4, 85mm f/2.8, EF 70-200mm f/2.8 L USM, and EF 24-105mm f/4 L IS USM would all be good for portraits.
But you said its for "people". Are you meaning candids or portrait work? Zoom lenses I think would be better for candids if you are trying to be discreet or catch fast movement. Prime lenses would be better for portraits.
Also, I think this thread would probably serve you better in the Equipment & Services: Reviews, Advice, Etc. forum section, since this section is more for galleries. ;-)
What do you want to do that your 18-55 lens isn't doing for you now?
If you just want a better lens in that range...the Canon 17-55 F2.8 IS would be a good choice.
My 35 1.4 LIVES on it's own camera. It never comes off of it. It's my favorite lens ever.
Depends on the photograph. Elsaspet shows clearly that she gets fantastic results with a 35mm for taking brides and lovely wider angles.
However if you want to take a headshot with the same lens the bride will end up with a very big nose. I'd aim for a 50mm for general purpose full bodies and waist up, or 85mm for some headshots. I have even used my 105mm lens standing a few metres away to get a shot I was after.
ALL good advice!
Pete
I agree with NJ
An 85 prime would be awesome, and so is the 70-200 2.8 IS
Thanks so much guys!! Ive been away on vacations and such so I am just now getting back to this thread, hehe...anyway, I am getting good shots with my basic 18-55mm but I just want something a little more...professional I guess, haha. Thanks so much fo the advice!!
