OK, one by one now
Graflex with the 127mm Ektar is a good place to start. You can't get a lot of movement out of it but for the price it'd be a great place to start.
Just how far will you be hiking and what kink of detail are you looking to get? As Helen hinted medium format does pretty good and is much less bulky. A Mamiya 7 with a couple of lenses wouldn't take up much space and 120 film is much less of a bother than 4x5 and larger. Getting a good drum scan on negs you like isn't too costly either, all things considered, and will blow you away. Granted, getting the same on a 4x5 or larger will blow you away further but then we get back to the question of how much you want to carry and for how far.
For some reason I do not feel well with the idea of using a Graflex, it seems to pose some limitations.
And as for MF, I did consider that some time ago, but to me it appears as a compromise. A good compromise maybe, but I prefer to have the option to scale down later.
Also this is not about having the most convenient format in terms of handling, but it is also about the process of taking the image, and LF just gives a different feeling here.
My hiking usually ranges from a couple of days to a couple of weeks away from civilisation (sometimes meaning no roads, no settlements, no huts, no food, no paths, no bridges) in sometimes cold or wet climate at the arctic circle, often in the mountains. Usually I take 3 up to 7kg of photographic equipment (35mm) with me. Some might consider this kind of expedition trip with an LF camera crazy, and maybe I will try it once and never again, but I at least want to try if it is feasible for myself. Would start with shorter trips first of course.
This is one of are top landscape photographers and he uses a Linhof Techno and other camers
About Joe |*Joe Cornish Gallery
I am interested in the Technica, yes. Thanks for the link!
I usually restrict myself to nothing larger than a folding medium format camera when out for a stroll (aka hiking) but I have carried my old MPP S92 - which is similar to a Technika. If I had had a lighter camera that is what I would have carried. Nowadays if I wanted to carry an LF camera while walking I would take my
Chamonix 4x5, which is a versatile, light camera with a good range of movements. They are also excellent value for money. For lenses I suggest reading
Kerry Thalman's website - it has some good suggestions for compact, light lenses that perform well. He also has camera recommendations, but I think that he wrote them before the Chamonix came out.
As mentioned above, "a stroll" is not what I am going for
Anyway, I looked into the Chamonix a bit already, being a bit sceptical with regard to build quality as I could never put my hand on one. But if you say you've got one and you seem to be happy with it ... and thanks for the Thalman website, seems there is some good info there!
