Light stands?
MattK0138
Ocean View
What do you guys recommend for decent quality light stands at a good price. Am I expecting too much to think I can get each stand under 75.00? I need 3 for flash strobes and 2 for off camera flashes.
Like most questions around here....it depends. ;)
There are many types & sizes of light stands...some are cheap, other are expensive but most importantly, some will work best for you personal situation.
For example, a big heavy stand will likely be more stable, which is always a good thing...but if you travel with your stand, or use it on-location, then a smaller size & weight may be more important to you. If you are just going to use it in-studio, then you may want a heavy stand...but some photographers are constantly moving their stands around so maybe not. Also, how much space do you have to work with? Big sturdy stands will have a larger footprint, which takes up space and creates more of a tripping hazard. Maybe a stand on coaster would work for you?
How much weight do you have to hold? Flash units don't weigh much, but studio strobes run the gamut from light to quite heavy. For heavy gear (or just for safety at all times) air-cushioned stands are great. That way, if the stand collapses suddenly, the light is cushioned.
You will pay a bit of a premium for a good brand name like Manfrotto...but they are a good brand, and most of their stuff is very high quality. Of course, if you just want/need something cheap...there are many other brands like Impact, that sell at more reasonable prices.
I'm not a fan of the cowboy studio kit. I have a couple, and the lightstands have a very narrow footprint, and seem pretty flimsy.
I have found that with any lightstand (the cowboy studio one included) that if the legs are weighted down they get infinitely more stable. I purchased a couple bags of #8 (you can go larger) lead shot from my local sporting goods supply store, and half filled a couple of thick sweat socks with it.... then tied the open end off. Each sock is about 5lbs now, and can easily wrap around the base of the stands. Night and day difference, especially when using umbrellas, or other modifiers that will make a stand front heavy.
Sorry, I don't ahve an answer to your original question.
I want to get quality stands. That will handle some weight. I am picking up 3 used lights but want to get stands that will last and I will be able to use for years to come regardless of what I buy.
Manfrotto makes a really nice 12' air-cushioned stand which is very solid and stable. It has no problem holding a monolight and umbrella or SB at full extension. IIRC, I paid about $120 each for mine.
I will take a look. Thanks.
