LIGHTROOM EMERGENCY
Koshua
I imported a folder of RAW files into LR from my session the other day. I edited all of the photos into a quick slideshow, then cmd + z (undid) all of my edits to the photos after I exported them (to a different folder). I then closed LR, thinking I would come back and edit the files that are now in the unedited state. I just tried to open LR and edit them, but my RAW files are gone from the folder, but the jpegs that I saved for the slideshow are safely in their folder (they were saved to different destinations, so there was no chance to overwrite). The RAW folder is still there, but there's not a single thing in the folder. I didn't delete them, and they weren't overwritten.
WHAT THE HECK IS GOING ON?
I think there is an option in either the export or another part of Lightroom to delete the original photo. Make sure this is not checked. As far as recovering your files... are they still on your camera memory stick?
Jim
Jim
It's never deleted the files on export before, and I did exactly the same thing! Sadly, they're not still on the card and I didn't back them up :( How bad will the quality suffer if I edit the saved jpegs?
there are more options available to change in a raw file, but the difference between the two is minimal - at least from my own experience. The jpg processes some of the things you would have to do in a raw file for you. As to why they were deleted... make sure the save folder is the same one you are looking in. I use LR and personally have not had this same problem.
Jim
When LR deletes my files they go to waste basket. Have checked there?
It is more common in LR to break the link to the photos. But when that is the case you still see the image in LR and with the exclamation mark. If the image is not in LR then you had to delete it, and then you still had the option to delete only the image in LR or both in LR and from the hard disk.
In LR about the only command you could accidentally hit is Alt-Delete, and that only removes the photos from the LR catalog and not from the hard disk. I guess you already searched for the photo files outside of LR. When you imported, did you have LR Add the files to the Catalog or did you Copy (or Move) the files to the Catalog and to a new location on the HD?
If you checked all that then I would do as the others noted and run a recovery software. If you have the top level Lexar or SanDisk cards then you get a full version of their file recovery software. If not then buy a program.
Do not do anything else with any of the hard disks that could have the images until you run the recovery software. Also, they can be on the SD card as well so also run the recovery software on that - before putting any more photos on it.
Try some undelete / recovery software before you do anything
What would you recommend? Would I be recovering them from the SD or my HD?
I've forgotten the software I've used in the past, but it's free shareware out there.
edit ==> Recuva ==> Recuva - Free Data Recovery tool - Free Download
The key as someone mentioned above is do NOT install it where you believe the image files were located.
When a file is deleted the operating system removes it's reference in the main "database" but not actually on the harddisk. So you do not want to install any software over that location where the files possibly are.
So install it on another drive. I can't recall if Recuva actually installs or not but just be weary of that.
Thank you so much everyone! I ended up just editing the jpegs I had exported as a quick workaround. I still have no idea what caused them to be deleted from the root folder, but oh well. I'll keep reading through this thread and check if I missed something.
Which option did you choose in Lightroom?
When you import in Lightroom you'll see options to "Copy as DNG", "Copy", "Move", and "Add".
If you say "Move" then the images will first be copied into the Lightroom Masters folder (wherever that is... one of my gripes about LR is that I want to set this choice and lock it... and am astonished at how many times I catch LR changes my "masters" folder from my big external storage array (which is what I want to use) and trying to switch it to a folder on my internal hard drive (which I don't want.) I have to check this carefully every time or I end up with multiple master folders. AFTER the copy completes successfully it will then (and only then) delete the originals from the source location (effectively making it a "move" instead of a "copy").
If you say "Copy" then it copies into the Lightroom Masters folder but does not delete the images from the source location.
If you say "Add" then it leaves the files where they are... but adds the meta-data info to the Lightroom catalog. This choice effectively means you don't want Lightroom to manage the organization of your images by keeping them all in one place.
If you say "Copy as DNG" then it will convert your camera-vendor's RAW images (e.g. Nikon .NEF or Canon .CR2) into Adobe .DNG files as it copies but does not delete the original camera-vendor RAW files.
The best options are to let Lightroom manage your masters by putting them all into one place ... meaning you'll choose either the "Copy" or "Move" choice. I usually prefer to use "Copy" from my camera memory card -- I'll erase the camera memory card when I'm ready.
But I must emphasize... I catch Lightroom changing the location of my "masters" folder with astonishing frequency. It doesn't _always_ do it... but it sure does happen a lot. I never had this problem when I used Aperture.
If I had to guess at what happened to your images... I'd say there's a good chance that Lightroom "moved" the images to a "masters" folder but it may not be the folder you think. So they may be elsewhere on your computer... but they're probably somewhere on the computer (they are probably not just gone).
You did what?! Why would you do that?
Lightroom never edits your RAW files. The catalog maintains the list of original (presumably RAW but they could be JPEG) files and also maintains a list of every adjustment you've applied. But those adjustments are not directly applied to the image itself. When you view an image, Lightroom opens the original RAW file and then also opens the list of adjustments you've made and basically re-applies all those adjustments to the "on screen" copy of the image you are looking at. Your adjustments never actually get saved into a real image until you "export" the images to a new file. You can always go back to the original images at any time -- or back out (or re-adjust) any adjustment you've made to an image.
There is never any reason to undo everything you've done. If you were worried your changes would somehow get saved into your original images -- no need to worry because Lightroom doesn't do that.
My guess is that Lightroom "moved" them to one of it's "masters" folders. I think Lightroom calls this "LightroomMasters" by default when you install the software and use it the first time... but it turns out you can name it anything. When you do an "import" you'll notice there's a "destination" section (if you're on the latest version then it's in the right-side margin of the user-interface).
It might be named something like: .../Pictures/Lightroom/LightroomMasters
Within that folder, however, is a folder for each "year" in which you've taken at least 1 image.
Within that folder is is another sub-folder for each "date" that you've taken an image.
So if I took and imported images shot today, it would be: .../Pictures/Lightroom/LightroomMasters/2016/2016-08-16/
And within that folder I can see all of my image files (the original files ... untouched ... straight from the camera.)
