- Joined
- May 1, 2008
- Messages
- 25,502
- Reaction score
- 5,111
- Location
- UK - England
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #1
So here's a comparison between Lightroom 4 and Camera RAW 5.6:
From what I can tell there shouldn't be a difference, but if you look the lightroom shot is clearly sharper and the noise has been sharpened as well, giving a much harsher view than the Camera RAW 5.6 (even though it should be similar/the same software).
I'm thus confused, Lightroom has even read this shots defaults and the sharpening and noise control settings are set the same:
Amount 25
Radius 1
Detail 25
Masking 0
Noise Reduction
Luminescence 0
Colour noise 25
(lightroom also has greyed out detail and contrast in these, I assume by greyed out they are currently not enabled - esp since the detail ones are both set to 50).
I'm not opposed to a sharper sharpening code overall, but the background has been rendered what I would consider in an ugly manner, esp compared to the much smoother versions that I'm more used to seeing. Is there some setting adjustment I can make to get a more similar appearance or have I got to tweak the values because lightroom has stronger codes?
Amount 25
Radius 1
Detail 25
Masking 0
Noise Reduction
Luminescence 0
Colour noise 25
