Lightroom Presets
lennon33x
Ok, so I know that there is a way to do this.
When I start making adjustments in LR, the first thing I do is usually remove CA and load the profile for the lens. I want to stream line all of my imports so that they can automatically do that. It's become a step that I want to avoid if I could just load of all of my imports similarly. I usually will make minor sharpness corrections, then adjust my shadows/highlights, then contrast and then some color corrections last.
I'm trying to create consistency in my work, and I want to make the editing process smoother so I don't spend an additional hour removing CA/loading profiles on 20 images (I'm exaggerating, of course).
Create it as a preset and apply preset upon import or just sync them all when you tweak one and go through and do local things ( crops, etc)
I just apply lens correction to one image, then i select all the images and use sync to apply it to every image. I also do this with noise reduction on images that share the same iso sensitivity.
