Liquid Emulsion Question
snark
Missouri
I am playing around with some "Liquid Light" emulsion I got from Freestyle. Anyone have experience using this stuff? I get a surprisingly good image with it, but before I can get it out of the soup the emulsion starts to come apart and I am left with some goo to wash down the drain.
I applied the emulsion to a flat, sanded piece of hickory that had been treated with sprayed gesso. I wiped the emulsion on over the gesso with my finger and let it air dry for 24 hours. I was going to develop it two minutes in Ethol, but after about 45 seconds the image started coming apart .
I did everything according to instructions that came with the emulsion. The length of time required for the emulsion to dry was not addressed, so that was a guess but it felt dry to the touch when I exposed it. An ideas what I might be doing wrong?
For wood and metal, an oil-based pre-coat, like polyurethane varnish, should be used for good adhesion as well as to prevent discoloration.
Thanks a million. I will give polyurethane a try.
