hamlet
- Joined
- Sep 12, 2013
- Messages
- 2,894
- Reaction score
- 435
- Location
- Belgium
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
This is true, but i cant hook it up to remote places.
This is excellent news! I could stay for the full 6 hours if i buy 5 additional batteries to add it to the one that came with the body.I'm not a Nikon guy, but typically the grips do let you use either one or two batteries (it is not necessary to have both batteries in).
I'm looking at the Vello brand grip for the D3200 and here in the US (I realize you are on the other side of the pond) is about $65. The battery door is on the back, so it'd be pretty easy to swap batteries quickly as they get low.)
When I do astrophotography the camera is imaging almost non-stop for several hours. That would kill any battery so the camera runs off AC power. While that's fine in an observatory because we actually have AC power, that's probably not available to you out in the field at a train station.
I'm going to have to see your setup as you live only 20 miles or so away. My astro stuff is simple unfortunately.I'm not a Nikon guy, but typically the grips do let you use either one or two batteries (it is not necessary to have both batteries in).
I addition to a battery grip there are some settings you can change to conserve power.
Turn off the preview on the LCD, and switch to manual exposure and manual focus. Turning those things off means the camera las les to do with each shot and thus uses less power.
