RRYANSMITHH
I'm considering the V300 and the V600. Can the V300 scan medium format negs?
Ryan,
I got my V300 last week and I've been using it a lot. It's awesome. =]
However, compared to the scans you can get from CVS or Walgreens with their drum scanners, the V300 isn't as good at all. But it's good enough IMO.
Are you scanning in auto? Scanning is a bit of an art. Until you get the hang of manually scanning your frames you wont get the best performance out of your scanner.
Yeah, I actually do scan in auto. What settings do you use?
I have an old Epson 3170 and only shoot B+W, so your experience may vary. Here's how I do it.
I scan both 35mm and 120 as Tiff, 16 bit greyscale. Click "Professional Mode", click "Preview". The scanner does a bad job of selecting the actual frame from the negative strip then tries to autocorrect for info that is not there. So, use the marquee tool to select your first frame. Select liberally. Click "Zoom", and adjust your marquee so that ONLY your image is selected. Click the the button that looks like a histogram. Now, the histogram you see will only include the info from the actual image and not the base fog from the strip. Use the sliders like you would on the "Levels" tool in Pshop. The scanner is good with highlights, not so good with shadows. Set your blackpoint so no info is clipped. Actually, set it a touch liberally as there is more info at the left of the histo than what shows up in the graph. Set your white point so nothing is clipped, not liberally (you most likely will have more than enough info there anyway). Now, set the midpoint to value 1.00. Minor adjustments in the midpoint will affect the tone curve. Sliding to the left gives you more values in the shadows to play with, and vice versa. Color works the same way except that you can adjust all three channels individually. If you have some Pshop skills the interface will look immediately familiar.
