Looking for Macro Lens Recommendations
Can a extension tube be put on a macro lens, and if so, what would be the result?
Yes they can and it just up's the mag even more, as they do on any lens.
I have been using the Sigma 105 macro on my Canon 800D and am very happy with it. The lens offers 1:1 magnification and a comfortable working distance; on my crop sensor it’s a 168mm FFE. It offers a focus-limit switch so you can match the focus range to the distance of your subject. But the lens also focuses to infinity and so works as a prime. The OS works pretty well, too. Extension tubes certainly cost a lot less and are okay in a pinch, but having used both I much prefer the macro lens.
Yeah, the L tax is costly. There's an f2.8 non L version of that lens which is very similar IQ wise and half the price of the L ;) Well worth considering.
Review of it here:
Thanks! I ended up getting a pre-owned Sigma 105mm f/2.8 from MPB. Cost was a factor. I looked at the Canon, Sigma, and Tamron offerings for EF mounts. The L was out of range at this time, and the USM doesn't have image stabilization, which I think is important for a guy with shaky hands like mine. The Tamron wasn't available new or pre-owned. I did some research on the Sigma, and decided at the price point, I could work with that. It will take a bit of learning, since it's a different sort of photography, and has it's own quirks.
extension tubes are cheap and can convert every single one of your lenses into a macro lens without any IQ loss.
Thanks! I should have come back to the thread prior to purchase, but I may still add an extension tube to my kit.
This is the one I settled on. I like that it can work as a prime, and I like the OS. I took it out for the first time. It will take some getting used to, because I'm so used to using a zoom to change focal length. Now I have to move myself closer or further away. I guess as long as there isn't a drop-off behind me, I'll be fine. :D
I'm looking to round out my kit with a macro lens. I have a Sigma 50-500mm, a Tamron 18-400mm, and a Sigma 17-50mm. Now I'd like to add a macro lens that would enable me to focus on the smaller world, from close to medium range. I found a couple of 18-200mm macro lenses (Tamron and Sigma, the Tamron is aspherical), but I'm not sure if 200mm is overkill, given what I already have. Suggestions to research appreciated. Will probably by pre-owned from mpb or keh.
You will want at least 100mm for satisfactory working distance, longer is better.
Older non AF macro lenses are out there and a relative bargain in most cases.
Unless the lens has other uses, AF is IMHO a waste of money on a macro.
I use the 60mm from NIKON on the repro bench only.
For macro work, I use the 100 mm, from NIKON as well, that I will combine
to a full contacts extension tubes dedicated to it.
Results? Since extension tubes have no lenses the quality remains at 100%
and one gains more flexibility on the macro factor with the numbers of tubes.
I decided on the Sigma 105mm. With these shaky hands, the OS the lens has comes in very handy.
Great success with Tokina 100mm. Macro lense. Great lens and good price. On par with Nikon macros
