LR not opening/ Windows
No, that (1) is ignored.
I typically add a few letters to the very beginning so the name and suffix are intact but it doesn't match the catalog name.
as in OLDLightroom 4 Catalog.lrcat.lock
the path to the prefs file is Preferences
C:\Users\[user name]\AppData\Roaming\Adobe\Lightroom\Preferences\Lightroom 5 Preferences.agprefs
Thank you Lew! I am going to do this later when I have more time to concentrate :D I'll keep you posted! Fingers crossed .
I suggest you delete the prefs file and rename those two files before you try opening LR again.
It may be a corrupted prefs file that is partially opening the catalog and leaving the lock conflict files.
good luck
Thanks for the help Lew!! It worked!!
What I did:
*unhide hidden folders (this was the step that I kept missing. the preference file was hidden!!)
delete preference files
closed application via task manager
deleted locked and renamed the other folders (conflicted folders)
restart and relaunch, load catalog (I had to load catalog with the renamed (colflict) folder for it to work).
And LR is back!! Yay, what a relief. Thank you <3
