Lunch Tote
shinycard255
IL
Well... here's another one of my product shots. It was slow at work so I had to keep myself busy. Shot is already torn down so I can't tweak the shot, but can tweak it in PS as need be.
C&C as usual, thanks!
When you stuff bags try to get out all the wrinkles...use cardboard and tape on the inside to flatten a large wrinkle...because of your blue surface your whites are on the blue side...shop the whites to clean up.
I've used foam core in the past with a combination of tape to help with wrinkles. Would just using tape help take out wrinkles or does it have to be the combination of the two? Never thought about using cardboard, but I guess anything that is sturdy will help. This was just stuffed with bubble wrap and was steamed before shooting to help get rid of most of the wrinkles.
Good call on the whites. I will do that!
