"Make A Wish..."
X Pro-2
f/8.0
ISO 100
1/500 Sec.
Fujifilm XF 35mm f/2 R WR
35 mm Equivalent 53 mm
(Processed In LR & Color Efex Pro 4)
Thanks For Looking Any Comments/Criticism Will Be Appreciated.
Cheers,
Enezdez
Nice shot. The bush distracts and blocks the building too much. You could have moved to the left a little. Also, the road doesn;t add anything to the shot. It's good to move around a little rather than jumping at the first view. This often gives a better perspective and view to shoot. Offsetting the building a little to create an angle view so it's not flat would add some interest and excitement unless you;re looking for a static shot. Then straight on is OK. Keep submitting. You're doing great.
I like the shot.
Unless I am trying to document a specific item or unique detail, I rarely take pictures of static things like buildings, bridges or even slow moving ducks on a pond, without adding some sort of foreground or framing objects. It is often tress or shrubs, even cattails and such.
I suppose if you had enough time you could have caught all three flags extended. :) :)
I like the shot.
Thank you both, I normally don't take these kind of images unless maybe it's a major landmark...but this is huge structure & more importantly, this is Make A Wish Foundation building, never seen one before....
