mattbaume
- Joined
- Nov 15, 2012
- Messages
- 17
- Reaction score
- 2
- Can others edit my Photos
- Photos OK to edit
I'm sure we've all experienced this problem: when firing a flash straight on into something reflective (mirrors, windows, tiled walls), the bright reflection of the flash "tricks" the metering system into underexposing the picture.
So, what are your ways of dealing with this? I'm interested to hear your techniques.
Obviously, the simplest way is to avoid shooting directly into something reflective, or position the subject to block the reflection, or move the flash way off-camera so its reflection is out of frame. But what about when that's not possible? (For example, I sometimes shoot at a nightclub in LA that has wraparound mirrors on all the walls -- which is both tacky and challenging!) I've read that Sony has an ADI mode that compensates for reflective surfaces, but I'm shooting on Canon.
The best solution I've found is to switch the flash out of ETTL mode and into full manual. Experiment a bit to find the flash setting that works for that environment -- often around 1/16 or so -- and then stick to that. But of course, that only works if I maintain a consistent distance between flash and subject. This technique also produces unpredictable results when shooting people with very different skin tones.
As I'm typing this, it occurs to me that I might also be able to use FEL to find the right setting, rather than experiment.
Any tips from folks who've dealt with the same issue?
