- Joined
- Jul 8, 2005
- Messages
- 45,715
- Reaction score
- 14,785
- Location
- Victoria, BC
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #31
Good point!Just quote someone and then say - "good point".this thread makes me feel dumb.![]()
I'm trying to get my brain wrapped around this concept...I will work on the three paper deal tonight. I'd like to be able to have that sink in a good bit more.
Think about it this way. The camera does not know the reflectivity of your subject(i.e. whether it is white, grey or black). All it knows is that most scenes have white and black in them and most average out to some level that is pre-programmed; as in the mythical 18% grey or 12% grey, or whatever.
So, basically, your meter is assuming you are looking at an average scene. It has a pre-defined idea of what it thinks is average or what will fit most circumstances.
You really throw it for a loop if you are metering a completely black or completely white object(like the paper experiment). In the case of the white paper, it will underexpose the shot to bring it up to a middle grey. In the case of the black piece of paper, it will overexpose the shot to bring it down to a middle grey. For your grey shot, it should be pretty close depending on what shade of grey you go with.
This is actually what Derrel showed in his 'example'. When he metered something white, it gave him a faster shutter speed. When he metered a black subject it gave him a much slower shutter speed. Basically, his meter was trying to turn what he was metering into grey because that's the only thing it knows how to do.
Current metering do more than metering into grey if you didn't know.
That depends a lot on how you have your metering set up and what type of scene you are metering. In the white, grey, and black piece of paper case, the meter will return a middle grey. The camera actually does a much better job metering complex scenes than very simple ones.
Personally, I do not use evaluative/matrix metering, and instead use spot metering 90+% of the time. I intentionally dumb down my meter so that I don't have to work as hard about predicting how it will react in certain circumstances.
If only there were a metering that only meters the brightest part of the scene.
There is, sort of. It takes about a second to take a test shot and look at the histogram.
How is a graph that outlines exactly where every pixel is located on the entire recordable scale in all three channels not accurate?If only there were a metering that only meters the brightest part of the scene.
Not really accurate at all.
How is a graph that outlines exactly where every pixel is located on the entire recordable scale in all three channels not accurate?There is, sort of. It takes about a second to take a test shot and look at the histogram.
Yes, white balance, tone curves, contrast, and in camera settings influence the histogram, but it's not that difficult to set your settings to get a fairly representative histogram.
If you can't interpret it properly, that is much different than just saying it's not accurate.
