Misc. Hasselblad Accessories and Parts
fstopusa
Knoxville, TN
I have been going through some boxes of stuff and came across a box full of miscellaneous Hasselblad stuff. Since I have not used a Blad in about 10 years, I thought I might need to get rid of this stuff. I would like to sell this stuff and get it out of here. Some of the items are in pretty good shape and some have definitely been used a lot. Some items are probably just for parts only and some are things that I have never used and are unusual. I am open to all reasonable offers. I don't have many posts here on the forum, but you can check out my rating on ebay by clicking here. I will be glad to provide pics of anything upon request.
So, if there is something you need for a Blad here is a partial list of some of the things I have:
  • Prism Finder with a small chip in the corner of the glass. It was probably dropped. The central viewing area is still fine.
  • Hasselblad brand Polaroid back with box and instructions.
  • 120 Film back, chrome, serial #UP422525. Missing label that tells that it is for 12 exposures and shows brassing etc. But, it has the dark slide, matching insert and seems functional.
  • 220 Film back, black, serial #UU273994. Definite signs of use. Has dark slide and seems to work.
  • 2 lens shades for 80mm lens. Worn and scratched but not bent and the fit on the lens nicely.
  • 3 Spare viewing screens in decent shape with cases.
  • Set of three Hoya b-50 mount close focusing filters in a case. +1, +2, and +3 filters. Glass looks good and filters are in decent cosmetic shape. The case is pretty worn looking.
  • Pop-up finder with magnifier. It stick when opening and closing and the magnifier has a small chip in the corner of the glass.
  • F80 Recharger/ power supply for EL or EL/M ( I think). I no longer have the EL/M, so I cannot test it, but I think it used to work fine 10-15 years ago.
  • Fuses for an EL body or charger.
  • Flash grip/handle with shutter trigger. A bit worn, but it still works.
  • Hasselblad flash extension bar for grip/handle. Used to get the flash up over the lens instead of off to the side. In good condition and look like it was not used much. Scratches etc from being in a case.
  • Hasselblad Quick Release tripod plate. Definite wear from use, but in good overall shape functionally.
  • Assorted film winder knobs.
  • Quick focus rings
  • Pivoting Flash attachments that clip on to an 80mm lens hood to hold a flash.
  • Pivoting Flash attachment that attaches to the side body name plate to hold a flash.
  • Some sort of lens adapter that connects to the Blad body and has a deep threaded ring on the other end. No identifying marks and I have no idea what it was used for.
  • Assorted filters, body caps, lens caps, lens cases, and straps.
I may find more stuff as I go, but that is the gist of it for now.
