amolitor
- Joined
- May 18, 2012
- Messages
- 6,320
- Reaction score
- 2,131
- Location
- Virginia
- Can others edit my Photos
- Photos OK to edit
- Banned
- #16
The point about the Bayer array is that you're literally trading resolution for chroma information. Using a sensor with no such array doesn't give you the chroma info, but you do get the resolution back. I don't have the math on hand for the bayer array situation, mainly because I haven't gone and looked for it, and I don't know or much care about the algorithms used.
I assume it is similar to the situation where you can trade resolution for bit depth. Audio systems routinely use 1-bit digital-to-analog converters, which are essentially an embodiment of this idea. They operate at insane frequencies, so you have enormous resolution (in audio terms - in electronics terms the frequencies involved are trivial) but almost no bit depth. By filtering the output, you lose resolution -- bringing the frequencies back into the range of audio -- and gain bit depth.
Anyways, you should be able to see the example with narrowband red light pretty easily, without doing any reading or even much thinking.
