MULTIPLE EXPO
minister
Delhi
I am trying multiple exposure shot with my nikon d5000 with bracketing EV it is ok But I want 6 to 8 multiple shot but i can't find any option
if I set ev plus or minus it makes no difference in picture and it's makes no differences in which mode i am
YES YOU ARE RIGHT FOR HDR
please help me create HDR
minister, you need to be in Av mode, you need to set up your bracketing step, ie 1 stop, 2 stop increments etc, then you need to alter your first exposure set to be under or over 0 shoot that and reverse.
Set mode to continous shooting.
Turn off Auto Focus and IS (or VR) if tri pod mounted
I use live view so mirror is already locked up to minimise any shake if tripod mounted.
ie: steps 2 stops
set exp comp to -2
fire off 3 shots
you will have -2,0 and -4
alter exp comp to +2
fire off 3 more
you will have 0, +2 and +4
This will give you 6 shots, with 2 around 0 exp comp. So basically 5 useable.
This is how I set my Canon up, Nikon may be similar.
Hope this helps
Sure I am going to give it a try
and what s/w u use for compiling
yes I have what expo you mentioned now how what S/W i need
there are a wide variety of software available, what is your price range? Then just google HDR software and you will keep busy for an hour or so just reading about your options.
try a few downloads and see what appeals to you. AND, you must be prepared to practice and work hard as this technique is more than just a few clicks of a mouse (at least to be good)
