my beautiful pink flower tree
Thank you Bitter Jeweler but do you know why my camera will not allow me to lower the aperture number? I love the effect with the DoF but my camera does not want to let me set it how I please. I am going to try with manual again. I have read online step by step how to set it and the manual. Obviously something is not clicking for me. I like the photo too even without as much .. what is it.. bokeh. I want to really learn how to create that effect without having to 'try' so hard. I feel that you more experienced people make awesome photos and it's so second nature for you, but for me out of 100 shots I'll like two, three tops. haha.
Manual shooting is NOT that hard. It requires one more step than a program mode.
It is daunting at first.
I will try to give you the basics.
This is your light meter.
It can be found on the back of your cam and in the viewfinder.
So here is your rundown of the steps you shoud take when taking a manual exposure.
Asses your light situation, to set your ISO.
Is it darker indoor lighting...Raise your ISO
Is it bright lighting? Lower your ISO
Use "evaluative metering" for now.
Ok, you assessed your light.
You are shooting a static object.
Now you make a creative choice for your capture. Select your DoF.
If you want shallow DoF, open up your aperture.
You want more depth, more in focus, close it down. Going all the way to f/22 is a little extreme in common situations. F/11 to F/18 is reasonable.
(this is a huge creative choice you make)
Now you need to set the shutter speed.
You need to change the shutter speed to get that white bar to zero. Then click your shutter!
Easy peasy, no?
If you are shooting a moving object, and you want to stop the motion completely...
Asses the light, set the ISO
Set the shutter speed to something around 1/250 (this is dependent on the speed of the object you are shooting, faster speed, faster shutter speed)
Now you change the aperture until the white bar is at zero.
Easy peasy.
Of course there are many combinations and desired effects you can achieve. But whatever you are shooting, you are trying to get the meter to zero, and your shutter speed above your focal length.
So, now you set you aperture to say f/11 but you can't get a good shutter speed to avoid camera shake? Raise your ISO until you can.
Say your aperture is wide open, but you can't get a high enough shutter speed? Raise your ISO.
To avoid camera shake (slightly OOF image) you need to set your shutter speed to AT LEAST the focal length of the lens you are using.
50mm? stay above 1/50 shutter speed.
250mm Stay above 1/250!
400mm Stay above 1/400
Often you cant get what yoou want, and you have to make choices. Raise your ISO and get more noise, or lower your shutter speed and risk OOF camera shake.
So again,
Static subject:
Set your ISO (generally, on location, you do this only once)
Select your DoF (aperture)
find the shutter speed that zeros the light meter.
Moving subject:
Set your ISO
Select your shutter speed (well above your focal length)
find the aperture that zeros the light meter.
Of course it gets more complicated. Zeroing the meter isn't always the best option. But this is exactly what the camera is choosing FOR YOU when in a program mode.
Shooting snow? The camera wants to make it gray instead of white, over expose it, according to the light meter.
Adding flash complicates matters a bit.
Now go take some pictures in complete manual! No flash!
I don't know why your camera wont let you. Maybe because it cant zero the meter with the settings you chose?
Holy cow bitter...so many words! More pictures less words :D.
Thank you for the steps. The problem I am having is that the aperture refuses to lower. It doesn't matter if I am in manual or A, it will NOT lower from 4, and it's not the lens. The lens allows it to be lower but it refuses to lower no matter how often I turn the dial. Has this happened to anyone before?
I have been using manual off and on, but I find it easier to use A or S right now just because I can not seem to get this aperture set. I don't know what I am doing wrong grrr. I have been setting the meter and everything else via the menu. The only part I can not set is aperture. Weird.
You're using a kit 18-55mm f 3.5-5.6, yes? You have to remember that as you increase focal length, your maximum aperture decreases (number gets bigger). At 18mm, you can set your aperture to 3.5. at 55mm, you can't, your max aperture will be 5.6. That's why you have a range for aperture. There are zoom lenses that have a constant aperture, but it's a more expensive lens design, therefore they are more expensive lenses. An example is the Tamron 17-50 f2.8. Notice it's not 17-50 f2.8-x.x. That's because you can have a max aperture of 2.8 at any focal length. With your kit, you can't. At about 30mm, I would guess your max aperture would be 4.0, as shown in the exif data from your pic. I suspect, tho I'm not sure because all my cameras say Canon on them, you get that "subject to dark" message when you try to go bigger with your aperture than the lens will allow at that focal length. Canons don't give you any message, they just stop at the max aperture allowed for that focal length. Hopefully a Nikon person will chime in. It's also maybe possible something is set in one of the menus, I dunno.
Oh, and again, out of focus backgrounds are called out of focus backgrounds. Bokeh is the visual quality of said blurring. ;)
Yes I was using the kit lens. I also now have a 55-200mm VR lens and I have one on the way that someone recommended, it was a 55mm lens. Okay I understand now. It depends on how I have my lens zoomed for how I can set my aperture. LOL . Wow I am such a ditz. Thank you for explaining, that was driving me nuts.
Whenever I put my camera down, I always set it to ISO 400, f/4, 125s shutter- just as a habit I guess. It helps for when you go to use it the next time to have a place where you always start, it will keep you from accidentally shooting at some crazy ISO.
p!nK
Thanks for the encouragement subscuck (btw your username reminds of something else .. submissive cuckold lol) .. good suggestion Mrpink.. I'm going to do that from now on.
