My first real attempt at people
nada87
Chicago-ish
I recently upgraded to a Canon T3i. So far I am just using the 18-55mm kit lens. Trying to decide where to go from that lens. I took these laying on the ground with the kids balanced on my feet to get natural happy expressions. Gave my legs a good work out. Please judge away!
I like the idea, but by shooting this way you create an exposure problem. Effectively it is a backlit portrait. Or a poorly lit subject against a bright background. To pull this kind of portrait out you need a reflector if the sun is bright, or a flash. Alternatively shoot at sunset, positioning yourself so that the low sun lits ther faces. Otherwise your portraits will be underexposed or , if you expose for the face , your background will be overexposed and washed out We can see both here.
Sashbar nails it....
But i'd add that the angles you've chosen are creative and show that you're trying something different - which is always to be applauded.
Sort the exposure problem and do it again!
ps - if you use flash then bounce it off a reflector to the side of camera (you flash may swivel to allow this even if top mounted)... A reflector is a great investment.
