My Grandfather's old barn - exterior shots
rlemert
Raleigh, NC
While I'm not a complete newbie to this forum (I have commented a time or two on other people's photos), this is my first attempt to post any pictures of my own. This is primarily because I haven't really been all that eager to set up a Flickr account, but tonight I finally took the plunge.
I'm actually going to try to split this up into two posts so that there are only four pictures per post. That way, if you feel like commenting (C&C) or editing, you won't have a huge set of pictures to wade through. My subject is the old barn on what used to be my grandfather's farm. I grew up playing in that thing, and it saddens me every time I return home to see how far it's decayed. I know these pictures won't have the same emotional content for you, but maybe there will be enough artistic content to make up for it. I took these pictures last July during my last visit home.
I'm going to post four exterior shots (with comments) here, and four interior shots in my follow-up post.
1) This shows the back side of an old equipment shed with the barn in the background. This was all pasture land when I was growing up, but it's since had a filbert orchard put in place.
2) This is the back entrance to the barn. That open door leads into the milking room, and there used to be a ramp on it. (I'll have a picture of the interior in my next post.) I also think the big corrugate tin door doesn't fit - it was added on when we still actively used the barn for equipment and supply storage. (I also feel this picture is the weakest of this set - it's too washed out. I'm still having trouble getting good exposure settings.)
3) This is the front wall. You can begin to see the construction techniques they used to assemble these things. I like the texture and the old wood tones. The pipe has shown up over the years - I'm still not sure whether it adds or detracts from things.
4) This shows what's left of the old hay elevator on the barn's north face. Once we'd stacked about 16 bales in a rope carriage, someone at the other end of the barn would start backing up a tractor. There was a 1 1/2 inch diameter rope tied to the tractor that would lift the carriage to that plate on the end of the jutting beam. The carriage would then slide along the beam until someone on the ground yanked the release rope, at which point the carriage would open - dropping the bales into the hay loft.
Interesting images of a past way of life, at least for a lot of us - thanks for the helpful explanations as well. You indicated that you are having trouble getting good exposure settings . What metering mode were you using, because )1 and 4) do not look too bad?
Cheers,
WesternGuy
I generally use Aperture priority (unless there's a lot of motion I need to control), but I will also frequently try multiple shots with exposure compensation applied.
(This actually has caused me several problems. I keep forgetting that I've got the compensation set, so I'll take a whole set of under or over-exposed pictures.)
You could try some shooting with bracketing on (if your camera has bracketing?). Then you will get an over an under and a mid range exposure of the same picture. You can then check the settings for the image you feel looks best, and set your camera to those settings...
Would even work for WB as well, if your camera does it. I know mine has the WB bracketing and exposure bracketing available. I used that alot at the beginning to see how different exposures looked at the beginning of a shoot.
That is a pretty awesome barn, my friends grandfather has a barn and I'll most likely be going out their soon with her and bringing the camera!
They all seem a little overexposed; #2 and #3 to a larger extent. It loses a lot of details in the blown out highlights that would make it more powerful.
Other than that though, very interesting pictures. If i were you I would stay out of the barn, looks like it might just fall over on ya (;
My mom is obsessed with old barns. Whenever we would drive together and she saw a barn.. she just would need a picture. It was interesting; barns were just her thing. I really like this barn though! Its not red ;P
That's a shutter setting. What I was curious about was whether you were using spot, centre-weighted, partial or multizone metering. You might want to try different metering settings to see if that helps - maybe it isn't relevant, but it would be to me in your situation. Just curious and trying to help - that's all.
Cheers,
WesternGuy
P.S. There's always HDR.
Oh, sorry. I just checked, and all of these had spot metering. I do tend to forget about that setting - guess I'll have to add it to the mental checklist.
The first is the best to me. The others seem a bit blown out, not bad but more than my liking. Great pics none the less
