My lens is lose for some reason is this normal?
raffile
Missouri
Excuse me if I am not explaining everything correctly here. I have the nikon d7000 and it just came with I guess a standard starter lens. But for some reason I can feel it moving about and 1/8 inch or so while focusing. I am honestly a NOOB here. I have just started getting into this stuff and I am trying to figure all of this out. But I will have a lot of questions, I know. So hope you don't mind helping me.
Anyway yeah the lens moves it seems from the base of the camera when focusing. It's not bad but its noticeable. Should I just take it to get it looked at you think? Or is this normal?
Not on any of my DSLR's, the lens doesn't move from its base when focusing.
take it in for a look see...
also it is put on properly right? i mean...just gotta cover the basics here. otherwise ya take it in. it should not for any circumstance during normal operation should it ever​ move from its base/mount point.
I have a question along the same lines - I have a D7000 and I didn't notice this problem until I mounted the heavy 300mm f/4 I got - Between the TC and lens it feels like there is about 1/64th or less of rotational play on the bayonet. I don't think that this is a problem because I don't see any really negative effects on the photos so far - though I'm still only getting about a 50% keeper rate or less because I'm still learning how to use the lens and I don't have a good tripod or remote release. Is a very tiny amount of play acceptable/common particularly with a larger lens?
Don't hold heavy lens/body combinations by the camera body; support the lens and let the camera perch on the end.
On a solid-metal body like the D700 and D3 there will probably be no problem but there's no sense putting torque on light weight bodies.
Tiny amounts of play around the mount are not uncommon and are a perfectly normal part of manufacture tolerances. It shouldn't have any negative effect on lens nor the camera.
I never hold by the body alone - the slight rotation is just a bit noticeable because of the length of the heavier lens. I typically rest the foot of the tripod mount on the flat of my hand or use my monopod. Thanks confirming that a small amount of movement is not a problem - good piece of mind.
