Applefanboy
- Joined
- Feb 13, 2008
- Messages
- 156
- Reaction score
- 0
- Can others edit my Photos
- Photos NOT OK to edit
DUDE!!! That is SICK! I want one. Seriously. I need one.
There's probably a thump screw somewhere that adjusts fan-speed and if not there's a utility hiding (or downloadable) somewhere that will allow you to set min/max speeds for certain temperatures.
Yeah, xeon processors do NOT need water cooling! It's one of the main design principals behind xeon. You can run them in an open case with no airflow and nothing but a passive heat-sync. The problem with doing something like that in a closed case is that the drives, RAM, and display adaptors overheat. Your 8800's and drives could actually benefit from water cooling...
Another thing you can do is get a realtime temperature monitoring utility and start unplugging the fans one at a time. Run a game for 10min. Check to see if everything is still good and repeat till you only have the actually affective ones plugged in.
Here's my system with passive cooling (no CPU fans), two slow exhaust fans out the back at 1321 RPM, one out the front at 1301 RPM, and the PSU fan running at 1709 RPM (So 4 total all at VERY slow speeds. These fans do 480 RPM ~ 10,000 RMP):
That machine is -- 12 fans!!!!!
darn you might be able to run crisis as full spec -- without lag!
should last you at least 2 years without upgrade
have fun!
Oh hey... that's good information.
So then most likely if I knock it down to 1 drive (instead of the 4) and take the second 8800 out, I'll probably be fine in my Antec P180 case. I probably will pickup cooler/fans for the procs because I don't mind a LITTLE additional noise... I just don't want a freaking wind turbine in my office.
Thanks, Bi... you rock!
Unfortunately, I think I'm stuck running Vista on the stupid thing because of my need to play games. I should try XP and see how that works out though... I would really PREFER XP.
BTW for those of you screaming in horror on my removing the second 8800... I'm running just fine on an 8800 GTS 320, which is a fair notch less powerful than a single 8800 GTX 768, so it will still be a big bump for me. Taking it out cuts down power, heat and complexity. All big wins in my book. Esp. since the 8800s have been way outclassed by the current boards out there... so in 6 months I'll buy a new vidcard and have more than I had with the dual 8800 sli anyway.
Nice machine, REAL nice machine. Some of these machines are now running upwards of $15,000.00 CPU (Computer Power User) Magazine and Maximum PC show a lot of this type of stuff. Most, if not all of these machines are built for those gamer types. The one I read about had basically a refrigeration system in it and before it booted up, it cools off the CPU to 0 degrees Fahrenheit
Hm, you know, that's an interesting idea. Question is how does Server 2003 handle games? If at all? This is a gaming rig, after all.
The people who saw me run Windows 2003 Server laughed. Well who's laughing now.
