Basic stuff would mostly be retouching colours or contrasts, I showed a different variety of edits, not just basic. Second, "spamming a community" ? This website allows up to to promote our websites, which is what I did. If you don't have anything constructive to say, I suggest you don't say anything at all.
Typically people here are not 'promoting' a website that sells services to the members, but websites that display their own photography.
What you are doing is what is called '
advertising.'
Constructively I can say that your work as shown is way, way below the quality level that anyone I know would expect.
In regards the website, using public domain or creative commons sources for edits really screams beginner without clients or one's own work to provide examples..
Not believing in yourself enough to spend a couple of hundred dollars for a basic website using any of the many theme-based sources signals insecure and inexperienced.
Well I have had photographer opinions view my work and certainly do not find it "way way below" in quality level. You also may not be a fan of it because you use your own methods or you are only into detailed looks.
It has nothing to due with "only being into detailed looks". If you want to have a go as a professional retoucher, you need to demonstrate a mastery of the skills most commonly associated with the field.
First would be dodging and burning. Knowing how to accentuate shape and form through the manipulations of highlights and shadows. Dodging and burning is like painting; very simple in concept but can be difficult to master. I don't see any examples of dodging and burning on your site.
Second would be skin retouching. Being able to fix blemishes in skin without making it look like plastic (on in the opposite direction making it look like a plucked chicken). Fixing skin and dodging and burning are where most retouching time is spent.
Third would be color
corrections. Not changing colors, correcting them. Knowing where things like skin and grass should fall in RGB or CMYK values and knowing how to get them there when they don't. Being able to color correct an image and make sure that those colors are properly within gamut for the intended output medium is critical.
Next up would be color grading, something else I don't see demonstrated on your site. Creating a cohesive color palette for an image by blending in other colors to help pull the palette of the image together for a more pleasing, harmonious look.
Don't forget the liquify tool. Being able to slim down a subject, or fix, for example, an arm that may have had some weight added via perspective distortion.
Proper sharpening for output is also important.
The ability to add "atmospherics".
etc., etc.,
My point being, you're not really "there" yet, insofar as being a professional retoucher is concerned. The ability to clone out people and objects from a background is considered easy. The ability to balance colors and tones isn't. Not because the techniques are inherently hard (they aren't) but because it requires a level of time, dedication, maturity, and attention to detail to get them right.
