Gaerek
- Joined
- May 2, 2009
- Messages
- 1,341
- Reaction score
- 98
- Location
- Tucson, AZ
- Can others edit my Photos
- Photos NOT OK to edit
i actually wasn't able to find many examples on here. just the suggestions here and there. i can't see how a 50mm lens would make a great portrait lens on film and full frame but a 35mm on DX would not considering they are basically the same focal length when adjusting for crop factor. you figure Nikon made the 35mm DX because of these reasons.
obviously there is no definitive right or wrong answer. this is one of those situations where what works best for you works best for you. in my opinion though i just see the 50mm f/1.8 being used as this catch all suggestion just because it's been around forever and it's cheap, when in real world scenarios it isn't that useful.
She has a D60. That's a DX camera. That means that the 50mm becomes ~75mm equivalent. The 35mm becomes just over 50mm equivalent. A lens that is DX only just means that it works only with DX cameras. An FX lens can be used on both, but if it's used on a DX camera (like the D60) you have to figure in the crop factor. In other words, the 50mm FX lens and the 35mm DX lens are not "basically the same focal length when adjusting for crop factor." There is a considerable different between them.
Anytime you put a lens on a cropped frame sensor, you have to take into consideration the crop factor. To recap:
50mm "full frame" lens on a full frame camera = 50mm equivalent
50mm "full frame" lens on a cropped frame camera = ~75mm (for Nikon, anyway.
35mm "cropped frame" lens on a full frame camera = will not work, or severly reduce your working megapixels
35mm "cropped frame" lens on a cropped frame camera = ~50mm equivalent
Most people will tell you that good portrait focal length is between 80 and about 120. That puts the 50mm on her camera closer to portrait length than the 35mm.
