Need help changing fuse Aikiphoto N200!!!
number3263
Quito
Hi,
I recently purchased an Aikiphoto N200 lighting kit from amazon.com and one of the first times I used it I blew the fuse. I´ve searched all over but I have no idea how to change the fuse ... no manual came with the kit and there is no information online and the most I can see is by taking the entire light apart.
Does anyone have any experience with this lighting kit?
Thanks
Hi,
Thanks
No manual came with the kit.
Did it come with a warranty? Contact info?
Damm that link didn't say where the fuse was.
No it did not, but it also did not say it was hidden, so I bet it is something obvious or easy to get to. Fuses, in general, are never designed to be in difficult to reach places.
I canot help you as I do not own them nor have access to them to look. Normally it should be pretty obvious where the fuse is, and accessible from the outside.
That fuse issue does seem a popular issue with your setup... a google search found this:
Blown strobe fuses... - Canon Digital Photography Forums
Remove the power cord and you will notice the little words 5A FUSE.. you will need something like a small flat head to remove the fuse. Its stored in the top area of where the power cord goes and you have to pry it out with a flat head screw driver.
view the pic I've attached
