Need help connecting new monitor
Evertking
How do I turn this thing on?
I just replaced an OLD monitor but the computer is not old and was built not to long ago. I have a VGA cable hooked now but the monitor says "no signal" That's where I'm stuck now. I remember the guy telling me one time that if I did replace it, I would need a cable.
Do I need to grab a HDMI??
I'm not to computer savvy...
Thanks
I have a BenQ led monitor and the computer was built by a shop and has a ryzen processor. That's all I know and I see on the back of the desktop a dvi and a HDMI.
Do that help at all?
What port does your monitor have? I’d just match up whatever it has.
Looks like you have an HDMI port on that video card ... I suggest you pick up one, as I assume your BenQ monitor has at least one of those ports also ... much better than VGA
... I assume you are running Windows 10 (or 7?)
I suspect the BenQ does not default to using the old VGA so you would have to go into the setup to change that ... but I would suggest just going with HDMI.
Ok, I have a D-Sub connected to both the monitor and the computer and a HDMI and nothing.
So I need to buy a HDMI?
Thanks
