bratkinson
- Joined
- Dec 4, 2011
- Messages
- 1,643
- Reaction score
- 318
- Location
- Western MA
- Can others edit my Photos
- Photos OK to edit
I guess the first question would have to be...how many in the surprise party? This is another way of estimating how big a room will the party be in? This affects how far you can back up to get 'group shots' of 8-50 people at a time. Which affects how wide of a lens you'll need.
I shot a small party of about 20 people a year ago using my crop sensor 60D and 24-105, but also had my 16-35 when I needed to go wide. Good thing I had the 16-35 with me. To get a group shot with 6-7 people shoulder to shoulder and being able to back up about 15 feet maximum, I had to go to the 16-35 to get them all in the frame. Two rows of 3-4 people would not work very well as they were all approximately the same height. I decided not to use my external flash as there was enough sunlight coming in from the wall of windows on one side of the room.
Given that you're shooting in a lounge, I'd expect it to be somewhere between quite dark and very dark. Even with you 50 f1.8, going no flash probably won't cut it. I'm guessing the lounge may be somewhat crowded with other, non-surprise-party patrons, as well. So quarters probably will be tight. As such, I'd plan on using the 18-55 for to get the angle of view needed in close quarters. That will require the flash, as well. As TCampbell indicated, drag the shutter to get some illumination on the darker areas of the lounge without overexposing their faces. I'd also suggest bringing the 50 and/or 85 along, too, but leaving them in the car. The location may change, they may move the party to an outdoor area, etc. Better to come prepared for almost anything than to not have what'll give the best results.
