New member with a question or two
shwiz
United States
Hey all,
I am a newbie to photography. I have had only one camera in my life, and that is a 5.1 megapixel Sony Cybershot from the early 2000's, which is now trash because I can't stand the grainy-ness. I am also currently a student. Next spring, I plan to backpack through Western Europe and feel the need for a travel companion that can help me remember the sights. I think a DSLR is a good idea because there is so much more that I want to do except point and shoot, but I probably will not be able to spend more than 1000 bucks. I am a quick learner, and don't particularly mind reading the manual. I may be able to take a photography class, too, since they offer them in my college. I was hoping to glean some experience from users here before I make a huge mistake and end up spending a ton of money for a tool that I don't need.
The kind of photography I expect to do is spontaneous, more landscape and less portrait, in low light or good light, and I need the ability to zoom a decent amount.
What I was looking at is the Canon EOS M, which I like because it is not enormous like the Rebel T3i, maybe mated to a Tamron 18-270 MM PZD lens. Any thoughts? Does anyone know if these two fit together without an adapter? Any cameras/lenses I should look for?
I appreciate any insight or feedback deeply.
Welcome to the forum!
Why not look at different models of Canon DSLRs? Your budget will put you mostly with Yx0D/X0D models, entry level or advanced, if you want something better then look at 7D for example if you can afford it, you said you are a quick learner, i am worry if you go with entry level then not so long you want to upgrade so quick after, buying a P&S now for you will serve you for short time and then you will get DSLRs sooner or later no matter, then why not save time and money and go with DSLRs from beginning or as a start.
Some will take my advise as harsh and recommend to start with P&S or any cheap non DSLR camera, for that i will recommend iPhone too then, but if you want to learn better and quicker and be a serious photographer then start with DSLR, i started with a P&S and i didn't last long and bought DSLR and never looked back, even i lost that P&S and i never feel sorry about it, it was very nice P&S though that time.
shwiz; it sounds as if you are steering yourself toward a DSLR, which is a good tool, but that with an extra lens or two will add considerable weight to your backpack. You will want to take along a good tripod and a speedlight as well. Also, the spare battery and charging device, all adding to the weight and complexity.
A good P&S would be a lot easier to carry, and you can purchase batteries nearly anywhere.
Professional,
the EOS M is a DSLR, no? That is the one I like but I am not sure that the Tamron PZD lens is plug and play on it, and if anyone has had any experience with this particular DSLR.
Designer, I know it would be 100 times easier to operate and carry a p&s, but for the rest of my life the references I will have of the only significant trip I went on in my twenties will be grainy photos.
NO it is not. you need to under stand what DSLR stands for. DSLR stands for Digital Single Lens Reflex. The reflex in DSLR and SLR cameras is done by a mirror and the EOS M is a mirror less camera.
That being said, it does not mean that mirror less cameras are bad cameras, they are a relatively new type of camera. Eventually we will most likely see some mirror less cameras take a similar physical shape of todays pro body style DSLR cameras because that is the physical form that all pro photographers have become accustomed to. They will not be DSLRs but that is just a name that refers to the type of overall technology within the device.
Consider one of the Canon "G" series starting with the G11 (G12 and I think G13 are out). You get the ability to use manual control, shoot raw files, and very good noise control for a non-SLR. Even a new G13 probably won't cost you more than $500, the others possibly less. I find that up to ISO 400 (on my G11) the results on moderate size prints or projected display are pretty much indistinguishable from what you get with a crop SLR like the Txi's. 800 is very usable with a little noise reduction, and even at 1600 you can make a print up to 8x10 with no trouble. The weight and bulk are much less, and you get the equivalent of 28-140 on the zoom.
The EOS M is a "mirrorless" camera -- not a DSLR.
In a DSLR, there's a 45º mirror in front of the sensor. That mirror bounces the image up into the "pentaprism" which flips the image right-side up and "normal" looking. This allows you to frame-up the shot, set the exposure, and focus. When you take the shot, the mirror swings up, the camera captures the shot on the image sensor, and the mirror swings back down again. DSLR stands for "Digital Single Lens Reflex". It's called a "single lens" because the camera only has one lens and both you and the imaging sensor look through the same lens. The mirror which swings up and down is called the "reflex" mirror. (see: Single-lens reflex camera - Wikipedia, the free encyclopedia)
Point & shoots don't have a mirror. The mirror adds to the size of the camera body because it requires space in front of the sensor in order for the mirror to swing clear to take the shot. When the camera doesn't have a mirror the body can be much shallower (front to back). This is part of why point & shoot cameras are much smaller (the other reason they're much smaller is because they typically have rather tiny sensors.)
Another nuance of auto-focusing DSLRs is the focusing system. A point & shoot typically uses "contrast detection" focusing. "contrast" detection means the camera identifies how quickly contrast can change between adjacent pixels (typically across an "edge" in an image). The best example is to think of a barcode. If you take a photo of a barcode and that barcode is in focus, then the barcode is typically going to be solid black lines on a white background. That means every pixel in the image is either "black" or "white". There are no "gray" pixels. HOWEVER... if you deliberate de-focus the camera and look at the same barcode image, you'll see the black areas softly blur into the white... that means there are lots of shades of gray in the image. The goal of the focusing system is to try to find maximum contrast in the image -- which indicates that the image is focused. The analysis of the image is somewhat compute-intensive (more on why this is an important detail in a moment.)
In a DSLR, the camera uses "phase detection" focusing (although you can put the camera into "live view" mode which will make it switch to "contrast detection" focusing just like a point & shoot.) Phase detection focusing is MUCH faster. A partial prism splits parts of the image in a way which causes the image to appear fractured if the image is not focused. When the two parts of the split image align, the image is focused at that point. The computer can detect this VERY QUICKLY and it's not particularly compute-intensive.
This means that when you take a photo with a DSLR, the focus and shoot tends to be fast. There is very little delay. When you take a shot with a point & shoot, you may notice that the camera has a slightly delay (perhaps a 1/2 second) before the camera actually captures the shot (this delay drives action photographers and parents with small children crazy with frustration.) The delay is caused by the fact that the camera has to analyze the image to determine if it's focused and that takes a while because the analysis is computational intense. The manufacturer can make the camera do this faster -- it can be so fast that there's no perceptible difference. But speeding up a computer means you run it at a higher clock-speed. There is a direct relationship between clock speed and battery consumption. Also the near-constant use of the live-view on the back of a point & shoot tends to eat through battery power. A DSLR, on the other hand, can go quite a bit longer between charges.
Back to the EOS-M
The EOS-M is a called a "mirrorless interchangeable lens camera" (aka "MILC" which is pronounced "milk"). It has no mirror nor does it have phase-detect auto-focus (so it's similar to a point & shoot in that area). What it DOES have is the (a) the ability to allow you to change lenses for a more optimal lens and (b) it actually has an APS-C size image sensor. That's the SAME SIZE sensor that all Canon "Rebel" model DSLR bodies have as well as the 60D and 7D bodies (the VAST majority of DSLR cameras use APS-C size image sensors.) It also can use a lens adapter which allows it to use any lens designed to work with an EOS digital camera (and all functionality will work.) The EOS M does have its own lenses as well... but since it's a new model Canon only has a couple of lenses which are designed specifically for it.
The lens on a point & shoot cannot be removed and they also usually fold into the camera body when powered off. This makes the cameras fairly compact. The EOS M has a "body" which is roughly the size of a quality advanced point & shoot, except the lenses do not fold into the body. If you detach the lens and just put the body cap on, the camera is compact. But with lenses attached it's not particularly compact (not compact enough that you could just slip it into a large pocket.)
As the EOS-M takes DSLR lenses and it's the LENS which is mostly responsible for image quality, that means you can get the same quality images using an EOS M that you can get using a DLSR. (BTW, Canon wasn't the first to do this... the Sony NEX cameras are also "milc" cameras with APS-C size sensors. I believe Sony and Canon are, so far, the only two brands which offer an actual APS-C size sensor in their milc bodies. All other vendors use smaller (and sometimes significantly smaller) sensors. Physically larger sensors gather more light. Each individual photo-site on the surface of the sensor can have a larger physical size as measured in microns. Larger photo-sites means they are more efficient and collecting photons of light and it also means they'll naturally exhibit less digital "noise". So you would get great images from the camera. I've not used one so I don't know how responsive it is when shooting (e.g. is there much delay?)
For traveling across Europe, I agree that one "super-zoom" lens may be more ideal because it saves space and weight. Ultimately having "one lens" is usually not a good idea because the lens sacrifices image quality in order to provide a greater zoom range (lenses that zoom less -- or even lenses that do not zoom at all -- will typically have better image quality.) But this would mean you could get a convenient lens for travel and, if you prefer higher quality optics when you're not traveling you can always get other lenses later. You generally wont notice the image quality difference unless you're displaying your images in large sizes or making large prints. But if you really zoom in to inspect the detail, you'll notice there is a difference.
Whether you prefer a decent point & shoot (and there are some fairly advanced point & shoots) vs. a milc vs. a DSLR really will depend on how much of a premium you put on size & weight. The DSLR will, of course, offer the greatest level of adaptability, performance, and image quality, but it'll also take the greatest amount of space.
wow.....what inspiration and candidness. I truly appreciate the assistance!
I think the Sigma is now directly at the top of my list... =)
