- Joined
- Oct 4, 2011
- Messages
- 10,726
- Reaction score
- 5,468
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #16
Okay, well, I missed all the apparent initial drama about a portfolio. So, moving on:
1. That's a very cool field, and I can see why it attracted your attention. But the composition is lacking any real compelling interest. Much of that, imo, is due to the fact that the horizon is smack in the middle of the picture, so in this photo that should probably be primarily about the two sides of the field, HALF of the image is filled with the sky, and because it's brighter than the field, it draws the eye more. Cut a lot of that sky out, make the image more about the two-toned field, and you'll be getting somewhere.
2. Again, I can see why you were attracted to this. And while it may "just" be a picture of a leaf, it's as good a place to start as any. In any image, the eye tends to be drawn to the lightest part of that image. So here--you've got an extremely bright, almost white (what we'd called "blown out", or very nearly so) spot on the leaf, and you've got the brightness of the fence and sky in the background. Both of those things draw the attention away from the color of the rest of the leaf against the green of the grass. I'd crop out MOST, if not all, of the fence and sky, leaving mostly grass and leaf. Then I'd work on exposure, so that you can shoot something like that without getting such a bright spot on the leaf. Shooting at a different time of day might have helped--or simply using something between the leaf and the light of the sun to shade it a bit and keep it more evenly lit.
3. I agree that this is the best photo in terms of the "idea" of it, but again, composition is lacking. It's not JUST that you cut off the left side; for me, it's more that EVERY side is cropped off differently. The right side, we see the whole tire. The left side, a tiny bit is cut off. On the bottom, it's nearly all cut off, and on the top, about half of it is cut off. This would be much stronger if the whole tire was cropped off evenly. Don't know if it would be possible to get the shot without losing as much of the tire on the bottom, where the shoes are, but I'd say it would be OKAY to have the tire cropped off, as long as it is evenly cropped off on every side.
4. Just nothing here. Sometimes what we SEE simply doesn't translate to a good image. This is a total miss, imo.
5. This one confuses me, because the REST of the shots are pretty much the average, first-time-with-a-camera kind of shots. But then there's this--clearly thought out, a fairly evenly lit (though probably a bit off on the white balance), non-distracting background...not at all what I'd expect from a first time with a camera sort of picture. I do think you missed the focus a bit though--it looks to ME like the earbud inside the shell is more in focus than the one in the foreground.
Keep shooting!
Keep shooting!
