Aloicious
- Joined
- Mar 12, 2010
- Messages
- 1,661
- Reaction score
- 452
- Location
- UT
- Can others edit my Photos
- Photos NOT OK to edit
- Thread Starter 🔹
- #16
Don't know if this question qualifies as noob-ish, but how did you not get star trails with such a long exposure, and why doesn't the light shining up the arch kind of overexpose some of the picture?
if you look at it at 100% there actually is a small amount of star trailing, I probably should have done a slightly shorter exposure on it, but part of the reason the trailing isn't as noticeable is because the shutter speed vs star trailing is directly related to the focal length that is used, as well as what part of the sky is being photographed. the longer the focal length, the less time you can leave the shutter open before trailing becomes apparent. since that shot was at ultra wide 16mm, I was able to keep the shutter open longer without having as much trailing issues.
as far as the light on the arch, part of it was sheer luck, since I had no control over the accidental light spill of the other guy's flashlight on the arch, it very well could have over exposed it, however he just had it up there for a short time (maybe 1s or less), it wasn't actually shining on the arch for the entire ~60s exposure, combined with the fact that the actual light output of small flashlights isn't very much in comparison to most other light sources, I kindof just got lucky. however I did have to separate the arch from the sky and process them separately in post due to the differences in light temperature from the flashlight vs starlight vs city lights on the horizon, so it also made PP a bit more intensive than normal, especially vs shot #1 which is lit with a speedlight, so color temp was much less of an issue.
