Nikon 1 Series in 2023
VidThreeNorth
Lately I am trying out an old "Nikon 1 S2". This old "Series 1" camera only outputs a JPEG or a NEF (raw) file. It cannot even produce a NEF and a JPEG at the same time, so being forced to chose, I thought I would prefer the NEF files. Currently, I can only view a NEF in the camera view screen or in Darktable 2.6.0. My (old) version of Paintshop Pro does not support it. I tried updating my GIMP to the latest 2.10.34 and that also failed to load it.
As for Darktable, it does not seem to actually create an output file. It only creates an XMP parameter file to assist in creating one, probably in an Adobe program. If anyone knows how to make a JPG using Darktable, that would solve my problem. Since I do not have plans to use this camera much in the near future, I do not want to pay money for support for this particular format at this time.
Any thoughts?
I am including a couple of versions of a camera created JPEG. Looking at the detail crop version, sharpness is pretty good. It seems a bit contrasty to me.
It took me a while, but I did install "rawtherapee" (I think 5.9?) and gave it a try. Unfortunately, I ran into the same problem. I could not find a way to get it to save an image. It might have to do with my using Windows 8.1. It might be looking for stuff in newer Windows versions. Any advice would be appreciated.
”……..might have to do with my using Windows 8.1. It might be looking for stuff in newer Windows versions. Any advice would be appreciated.”
I think we found the issue. Starting with ver 8 MS started their new licensing program that required all venders that wanted to be included in their compatibility list to stop supporting older versions of windows. This included hardware and software. That means all newer software must remove any support for older versions of Windows. The end of backwards compatibility.
Much like how Apple now forces obsolescence on software after the OS updates or the hardware goes off the current approved list.
Try searching archives for older versions of your editing software, there is probably a release that will work fine with win 8.x. Violates windows EULA, but everyone ignores that silliness.
Geez. This is why I used to use Linux. I cannot afford to be buying a new computer. Trying to upgrade the software alone will probably not be enough. A "class action" will probably be necessary, brought by people with no money to hire a lawyer. It probably won't go far.
NX Studio 1.4.0 lists compatibility with Windows 10 and 11 x64:
System requirements
Operating system
  • Microsoft Windows 11
  • Microsoft Windows 10
Note: Pre-installed 64-bit editions only.
Installing now on Win 11 Home; I'll let you know how it works.
It looks like it works. I imported photos and though I didn't make any adjustments but it seems I can (though white balance was greyed out). D750 photos imported using the laptop's built-in SD Card Reader.
I have been using the Nikon 1 S2 a bit lately to see if I could add to the samples. For now, only 1 turned out reasonably. I was looking at bees on echinacea (cone flower) and of course, they always move just when you don't want them to. This bee looked a bit "dingy", which surprised me. Usually they are a cleaner yellow. I was thinking that maybe smoke from the recent fires was coating them?
[2024-01-02 spelling correction, 2nd line: "they"]
One problem that I run into a lot is that I tilt my camera. Partly this is because most cameras release by pressing a button on the right side, but I have found that even if I check everything, I do have a tendency to not hold my camera level. This has been more of a problem with my Nikon 1 S2 because it is so small.
This picture is from a set where level was hard to tell because there was nothing man-made to check against. As far as I could tell, out of 5 images, not even one was actually level. On the other hand, I think a couple of them are "acceptable". One might ask "why not just use more 'Dutch angles?'" I have taken "Dutch angles", but simply put, I generally don't like them. Sometimes I leave enough cropping space in a picture to fix it in post, which is my best solution, but on a small sensor camera, I do try to "tight crop". When I use the Nikon 1 camera, I do feel pressured in that direction.
Also thanks for all the attempts (above) to help me. I have found no solution to my lack of ability to fully use my Nikon 1 yet. It is not urgent. I can still use JPEGs, but hopefully someday I'll solve this.
Nothing new to say about past problems. I'm still using the camera. Sometimes it can be a challenge. I remember learning a bit about the fashion industry a long time ago. I'll describe this backwards.
This year, there was a particular red color that was around in the various gardens. DSC_2534.JPG is an example of it. Regardless of the exact plant, this color could be found all around Toronto. In fact, you could find it all around North America, Europe, the oriental countries, and pretty much around the world.
In order to have these plants around the city, the nurseries had to place their orders last year, or even earlier. In order to have them available to order, the farms had to grow them. To have enough of them, the farms had to start growing them at least a year, maybe two or three, before that. In order to grow them, the seed providers had to develop the seeds and plant cuttings a couple of years before that. They, in turn decided on the colors because the fashion industry decided on the colors maybe another year before that.
So these colors were decided, maybe six years ago, give or take. . . .
And yes this is how the overall "fashion industry" works, and no it is not limited to clothes. It covers house paints, and thus hardware stores, and of course food packaging and more, and yes globally. You might find it more dominant in some countries than others, but you will see its effect. Fun stuff, I guess. Anyway, this picture features red. It's a red plant that was popular around Toronto this year. It might be around a bit next year, but it'll probably be gone, maybe the year after next year. I'm not sure how I'll feel about that. . . .
"DeMille" Clouds
If you saw CB DeMille's "10 Commandments" there is a scene where a cloud comes down and the many people die mysteriously. I heard that this was actually photographed, but I don't remember by whom. Maybe it was the Director of Photography. Whomever it was, randomly saw a cloud formation and thought it could be used, so he stopped what he was doing and took the picture. I don't know how it was used exactly, but it was.
This picture is a cloud formation that reminds me of that. I have only cropped it and re-compressed it. The clouds have not been altered.
250404 April Bus Ride Lumix GF3 OM 15mm F8.0 Lens
So far, the April 2025 weather has continued to be unpredictable. A couple of days ago it snowed. Today was brisk but sunny. I used my "carry camera", the Lumix GF3 with OM 15mm F8.0 (rectilinear) lens again.
Usually I do my best to avoid "rolling shutter". This time I moved the camera at street traffic speed. This caused the "slanting" of the video image. I was just being curious. I wanted to see if I might end up liking the effect:
Actually, one thing I found was that when the camera was moving at traffic speed, objects were slanted more when they were closer. If you look in the distance, things straighten up. I should have expected this, but I didn't. It is interesting, but I still don't know if I like it or dislike it.
