is the 24-85 wide enough for you?Do you really have to ask ?
The 18-300mm VR is an ok lens but not very sharp, price you pay for having such a flexible lens.
On the other hand the 16-85mm VR is from all the feedback and reviews I read a very sharp lens and the 70-300mm VR is from personal experience a sharp lens so I don't see any comparison.
Get the 16-85mm VR+70-300mm VR
Almost the same combination I have the 24-85mm VR+70-300mm VR
Good luck
I have already replied to a former post of yours asking which lens to get the 24-85mm VR vs the 16-85mm VR.is the 24-85 wide enough for you?Do you really have to ask ?
Good luck
I have no problem carrying 2 lenses... Actually ill need to carry 3 now... 16-85 VR, 70-300 VR and an 85mm VR macro lens...I have both 16-85 and 70-300, these are two lenses I use most of the time. Both are very good, consistent performers. I would not even consider 18-300, because with such a wide focal range there is an inevitable drop in image quality. The choice is simple, if you do not want to bother changing lenses, ready to carry a heavy lense all the time, do not mind a slower AF, and image quality is not your priority and you can live with zoom creep then go with 18-300. If you want sharper images, faster focus, with less distortion and you are ready to pay for it by carrying two lenses, then 16-85, 70-300 is an obvious choice. Then again, it all depends on what kind of photography you are after. For most cases 16-85 enough.
A few things to note about the purchase you plan to make:
1) Is the 85mm for macro photography? Take a look at the 85mm 1.8G, which would complement everything you're starting with better. The 85mm 1.8G is widely regarded as one of the best value for the money lenses on the market.
2) If you're picking this all up at once, take a look at the 35mm 1.8G and/or the 50mm 1.8G to go with everything. Both are excellent lenses. Prime lenses are wonderful to have.
3) Consider picking up two 16GB SDHC cards right off the bat, or two 32GB SDHC cards. Your camera accepts two at once.
4) Have you researched your tripod? If you have, good. If you haven't, make sure it's good. I don't know much about tripods, but I know bad ones can be a huge disappointment.
But im getting $300 off on the lenses...1196$ for the D7100 ?
I got my new D7100 less then a month ago for 1050$
