nikon 80-200 2.8
No VR, no AF-S... optically they are essentially the same however (at least the 70-200 VR I), the VR II is larger step up IQ wise.
Having owned both I appreciate the difference between the two, however for the price difference (new) the 80-200 is a bargain. You can even find less expensive versions if you go to a single ring / push pull style (had one of those as well). I did notice more chromatic aberration with the 80-200, particularly the push pull one.
The 70-200 has more lens elements and more of them are ED glass (7 lens elements are ED. The 80-200 has 3 ED lens elements).
ED glass is used to reduce chromatic aberration at longer focal lengths.
The new AF-S 70-200 f/2.8G also has Nano Crystal coatings which reduce ghosting and lens flare.
You can see a graphic of each lens' construction, and details of each lenses features at www.nikonusa.com
I own it. I got mine for $550. Absolutely love it. Tack sharp.
Mark
Yep Best Bang for the Dollar Nikon 80-200 f2.8 zoom.
Good technique & monopod will help negate most of the advantage of VR.
Older push-pull one ring goes in the $350-$500 range. And slowest AF of the series.
Newer Two-ring still in production at $1200 new and $550-$900 used.
My Gal "Bertha" by orb9220, on Flickr
And their is the discontinued AF-S version of this lens going for $900-$1100. But at that price would go with the 70-200 f2.8 VR I version for $1300-$1600 used.
It's an awesome lens, just older. Optically the versions of the 80-200mm are just as good as the 70-200mm; nikon has claimed to make improvements to the optics over the years, but I don't see any difference.
I used the single ring 80-200mm f2.8d for years, and loved it. You can buy one of these for around $350-500 depending on condition.
I currently use the AF-S version of the 80-200mm (fairly rare/hard to find), it focuses a lot faster then the af versions, but not quite as fast as the newer 70-200mm. These typically sell for around $1000 used, which would lead me to recommend a 70-200mm vr1 instead. I got mine for a steal; so I can't complain. ;)
I've tried the dual ring version as well, and it focuses slightly faster then the cheaper single ring, but they sell for nearly double which isn't worth it IMO.
Great lens... had one before upgrading to the 70-200. Bought mine for $650, used it for two years, then sold it for $700. :lol:
I bought that from you, thanks for letting me know I got ripped off.
:grumpy:
:lol:
Well...
The 70-200 2.8 VRI was optically roughly as good (and occasionally NOT as good) as the 80-200 2.8. The VRI was fairly soft at times. The 70-200 2.8 VRII is noticably superior to both in my experience. Like, the thing is AMAZING.
One point that no one has mentioned... The 80-200 2.8 also focuses significantly slower than the 70-200 2.8 VRII on most cameras, due to the fact that it is a BIG heavy lens and relies on the focus motor on the camera... whereas the 70-200 2.8 VRI and II have an internal focus motor in the lens. Listening to 80-200 clock into place on even a D300 is pretty painful. whirrrr.... whirrr....
Also worth extending that point... if your camera does not have an internal focus motor, then guess what? No 80-200 2.8 for you. Your less expensive camera suddenly got a lot pricier. :)
That said, the 80-200 2.8 is a lot cheaper (as many have said) and the optical quality is really great. There are like 80 million of them out there so you can get them used for a pretty reasonable price ($650-800 as some others have pointed out, depending on age and condition). If you are more "budget conscious" (funny statement when spending this much on a lens) and looking for a lens like this, it's a real no-brainer.
Eh, anyone with a body that doesn't have an internal focus motor can pick up a Sigma 70-200 f/2.8 EX HSM for $799 brand new and be well served for many years.
errrrrrr... ok, but the Sigma really doesn't hold up to the Nikon. It's a good lens, but it's not the same.
Standard rule of camera gear... and particularly with lenses... you get what you pay for.
No? It's a dang good lens and if you miss a shot because you have to manually focus I'd say it's a sweet alternative. I've owned one, along with 2 80-200's and the 70-200, it served me very well and if it had VR (OS) I'd still be using it today.
Mallard by Light Artisan Photography, on Flickr
Sorry, I know this is a Nikon thread - shame on me. :lol:
We're talking about a qualitative comparison here, so that's always challenging, but it is well accepted that Sigma makes good lenses that are a decent and less expensive alternative if you can't (or don't want to) pay for the Nikon.
On a very rare occasion Sigma makes a lens that is either slightly better than the Nikon equivelent or fills a gap that Nikon has not filled... the Sigma 10-20mm 4/5.6 was an excellent example of this, and one of the very few Sigma lenses I own...
However... generally... Sigma is second best.
This is not to say they are bad. They are merely not as good.
It's also worth pointing out that the difference between an $800 and $2300 lens (even within the same family) is generally not NEARLY as huge as the difference in price... there is a VERY steep curve as you get closer to "amazing".
