The D600/610 is stuck with entry-level subsystems because it is Nikon's entry-level full frame camera.
• Multi-CAM 4800 AF module
• 2016-pixel light metering sensor
• No 10 pin connector
• No PC (Prontor/Compur) flash sync cable port
• 1/200 max flash x-sync speed
• 1/4000 shutter
You heard "the facts" above. Now what they really mean.
D610 shoots at 6 FPS, has a new 3 frames per second Qc or "Quiet Continuous" shutter. It shoots 1080-p video, offers built-in HDR.
No 10-pin connector??? WHo gives a crap,really. Instead , the D610 and MANY other Nikons use the $17.95 Nikon ML-L3 infrared remote control tranmitter.
Nikon ML-L3 IR Remote Control Transmitter 4730
No, the D610 does not have a 10-pin connector: thats a legacy from older cameras. It also does not have a PC port for hooking up a PC-cord flash unit, that's true. The D610 ALSO does not come with a phonograph player, nor does it have a built in film cutter like a 1944 Exakta 35mm SLR. It also lacks a built-in cigarette lighter and also does not come with a cassette deck. Why? It is NO LONGER 1974. Or even 1984, nor even 1994, and it's also not 2004. We need a new brick of ice for the icebox.
1/200 second top shutter speed with flash....ohhhh, ANOTHER utterly unimportant non-feature, the lack of 1/250 second X-sync. Maybe she should spend $7,000 to buy a D4s to get a 1/250 second flash synch speed? A whole third of a stop faster...woo-hoo! Call the band--Johnny's home from the war!
"Only" 1/4000 second top shutter speed? Adequate for the first 150 years of photography were top speeds wayyyy slower than 1/4000 second. Top speeds that began around 1/30 second, then by 1930 1/300 second was a common top speed, then 1/500 second. Until the 1970's, 1/1000 second was the top speed on MOST 35mm cameras. For many years, 1/500 second top speed was pretty much the absolute top speed possible on leaf shutters, with as I recall, only one specially-designed shutter that could reach 1/800 second in a leaf design. The fabulous Hasselblad 500C and 500C/M topped out at, you guessed it, 1/500 second. OMG, how did we ever live without 1/8000 second shutters and 650 cable-channel TV packages and Netflix on demand?
ONLY 39 autofocus points. Hmmmm, the Leica 35mm cameras had ONE point, and were the world standard best-made camera for street and documentary use for five decades, and they had to be focused by hand, in ONE place....Hmm...another non-issue. NO FULL frame camera, from ANY maker, has the AF area coverage width of a DX camera. Canon used a 9-point AF diamond in the 5D, then added a few "helper" AF brackets, hidden, not marked, in the 5D-II, and yet, those were the top wedding cameras for eight years, in the FF class. PRO, flagship bodies Nikon D1-D1h,D1x series had what was it? Was it five AF points? And the D2 series topped out with 11 AF areas. So somehow 39 AF points is a bad thing?
