SCraig
- Joined
- Nov 12, 2011
- Messages
- 6,474
- Reaction score
- 2,451
- Location
- Nashville, TN
- Can others edit my Photos
- Photos NOT OK to edit
I shot this early this morning and was pretty pleased with the results so I thought I'd pass it along for anyone interested in the Sigma 150-500.
It was shot with my D7000, a Sigma 150-500 at 500mm, and a Kenko Teleplus Pro 300 AF 1.4 DGX TC. I also removed my UV filter. Total focal length was 700mm (1,050mm 35mm equivalent) and the focal distance according to the EXIF data is 112.20 meters (368 feet). It was shot from a tripod, obviously, using a wireless remote and with my camera set for a 2 second exposure delay after the mirror raised. VR was turned off if I remember right (the EXIF data shows "On" but I'm pretty sure I turned it off on the lens, so I'm not 100% positive). Exposure was 1/250 second at f/9 and ISO 400. The original image is 14-bit RAW with noise reduction off. Autofocus was on and I used single-servo, single-point autofocus focused on the heron.
This is the relatively heavily cropped "Final" version .....
Here is the original version. No adjustments at all except embedding an sRGB color space and resizing it. Rather low contrast but nothing that can't be fixed in post processing. I don't think all of the lack of contrast was just the lens and TC but I'm sure some of it is. This was shot straight across a lake and there is always moisture in the air over lakes in the morning. Not heavy fog, but I always have a slight loss of contrast when shooting across water around here in the morning.
Here is a heavily cropped portion showing the detail in the bird. Some noise, but again nothing that can't be easily fixed.
Considering the distance and the fact that I was using a TC I was pretty pleased with the results. I've always had pretty good results with this lens but this is the first time I really tried to use it with my 1.4 TC.
