Both the FM and the FM2 are legendary film cameras. I'd be sure that the light seals are in good shape. Other than than- I say go for it!
Exactly where mine gave out- at the hinge.Don’t forget the FE/FE2. Same form factor with an aperture priority option. Same bomb-proof build quality. The only failure-prone light seal is at the door hinge, which is also the easiest to change. Inexpensive thin adhesive-backed sheet foam from a craft store works as well as the over-priced “kits” for this application.
