Old Leica Books
Those same books seem to be selling for between $15-35 (for the one on the left) and about $7-$10 for the one on the right.. on ebay
You're missing something very simple, see the same listing on the French and German and UK portals:
Schneider Super-Angulon 120mm f/8.0 MC Lens - Linhof Ver. | eBay
The .com, .de, .fr, .co.uk in the URL is only indicative of the portal you access through. It doesn't indicate which country/portal an items been listed through just that Ebay doesn't use that part of the URL to indicate country etc in a search.
Ian
talk about false advertising!
"Stand at the sidelines but still easily shoot the winning goal with the telephoto Schneider Super-Angulon 120 mm lens."
"Shoot decent photographs even in dimly-lit conditions with this Schneider Super-Angulon f/8.0 lens."
"So get the Schneider Super-Angulon 120 mm lens and your hobby of photography will turn into a fiery passion".
The lens is an f/8!!!!
Well spotted :D
The seller also has a 10x8 Deardorff listed I'd suspect the 120mm f8 SA might have been used with it as an Extreme Wide Angle. Although technically it doesn't quite cover the format ot's quite a common usage. It's a reasonable price but I acn't justify it . . . . . . .
I chose 120mm Angulonn as a search knowing they and the 120mm Super Angulons aren't that common, and it did show well that an ebay.com search pulls up items from all around the world.
There's a CZJ 250mm. f3.5 Tesar listed as a Telephoto, it shows the sellers have no concept of focal length in terms of film format. This could be a superb lens for 5x4 portraits, however it dates from mid WW1 and is probably ex German military possibly from an aerial camera and is essentially just the lens in a barrel without the mount it sat in with aperture control etc, so useless.
All goes to highlight the inaccuracies of listings.
Ian
It's because you're looking at it through the portal. On the other side of the portal everything is reversed so f/8 is really a fast lens and wide angles are telephotos. It's called Einstein's Theory of Relative Portalocity.
In a portal no one can hear you scream, "B.S.!"
