jcdeboever
- Joined
- Sep 5, 2015
- Messages
- 19,860
- Reaction score
- 16,082
- Location
- Michigan
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
Yep. The sensors Pentax put in the K1000's weren't very good.![]()
OK, it's late on a Friday night. Meant the light meter-sensor-indicator-thingamabob. You know..... that little movey thingy at the bottom.
Man, I need to go to bed.
If you mean the meter quit, there might be a very simple fix. All you need is a 2.0mm JIS screwdriver to find out. (you might get away with a small 'phillips' jewelers screwdriver, but you run the risk of damaging screws)
Start by removing the battery, and lay it and the battery holder/cover aside.
Remove the three screws that hold the bottom plate on the camera. Important note: Although all 3 are the same thread size & pitch, the middle one has a slightly smaller head. So you'll need to keep track of that one. Once the 3 screws are safely stowed away, separate the bottom cover of the camera by pulling it straight away from the body.
The place where the button battery sits is a small, moulded plastic piece held on by another 3 screws. Remove those screws. There might be a small wire in the way of one, so you'll need be carefully move it out of the way. Then, the plastic battery part should simply lift away from the camera. But don't pull too hard.... there's a wire attached to the other side.
Or..... is there? If the connection got corroded, the wire has become disconnected from the battery terminal attached to the plastic piece. If you have access to a small soldering rig, you can simply resolder the connection and reassemble everything.
Presto! A working K1000 meter!
I've rejuvenated 5 or 6 K1000s 'dead meters' this way over the years.
Excellent breakdown, spot on. I can't believe you remembered all that, amazing!
