Pixe BG-E11 Battery Grip Use Method
Link Delight Online Shop
Official Vendor
Supporting Vendor
Vertax Ell For Canon BG-E11 battery grip has black appearance, adhering to the black has the atmosphere, a variety of elegant temperament. Carton using the same material as the body, through the implementation of various parts sealed, with the same camera waterproof and anti-dust performance drops. In addition to vertical shoot with a faster door, also equipped with a multi-function control button and multi-function custom buttons, can be achieved with the same horizontal position.
1. Remove the battery from the camera.
2. Remove the battery compartment cover
3. Put the battery compartment cover into the store to avoid loss. When removing the battery compartment cover, gently hold the battery compartment cover of the shaft, and the tilt angle upward pull it out.
4. Remove the protective cover, and then inserted into the electrical contact points of the camera battery compartment
5. Aim the set screw and camera tripod holes, then tighten handling knob.
6. Install the lithium battery: After aside, according to the reverse rotation indicated by the arrow, then pull out the battery clip (BGM-E9L).
7. In the battery clip (LP-E6) put into single or two batteries LP-E6.
8. Put the battery clip into battery grip.
9. Close the battery compartment and lock handle.
10. If only a single cell, it can be installed in the right or left.
If you install two batteries, both battery powered simultaneously. You can load two different types of batteries and make no problem to use.
When long time not using the camera, remove the lithium battery from the battery grip.
