I was going to say the same as Thorhammer and MarkC are saying here: there is no need to go and LOOK for good places to photograph, if you start developing an inner eye for the frame, you can frame about any place, subject, thing, matter ... check out the latest photos of our member Spako for things to photograph even while you are at home, inside your own four walls ... there are many others here but Spako comes to mind immediately right now.
And you must learn to see. Not straining to look for THE place, just see. And if you feel that you wish for high mountains, deep rivers, thundering waterfalls, deep lakes, an ocean or any of those things that just are not on everyone's doorstep, switch your views to what is there. Frame it, go up close, frame the detail, see if it works ... if you take digital photography your chances to go wrong without any losses are enormous ... and you might find out there is so much to see and frame right around you. And with the changing seasons, light, depth of focus you can play so much that there may always be a good new photo of the same thing as your result.
