Sw1tchFX
- Joined
- May 3, 2006
- Messages
- 7,499
- Reaction score
- 478
- Can others edit my Photos
- Photos NOT OK to edit
If you've got the 50 1.8G, don't get the 1.4G. The difference is subtle at best and you'd have to look hard for it. Also, the 1.8 is sharper. I own the 1.4G and i'm thinking of replacing it with either the 1.8G or 1.2L and switching to Canon.
the 35mm f/1.4G is only OK at f/1.4, it's awesome at f/1.7-2. I own this lens, and unless you're shooting Film/Full Frame, don't waste your time. The 50mm blurs out backgrounds more effectively and AF's more consistently too.
The 85mm f/1.4G is awesome..when it's in focus. I've rented it on occasion and have always had focus issues with it. I rent the 1.8D if it's available instead usually.
If you want something that will blur those backgrounds more than what the 50 does already, look into the 85mm f/1.8G. It should be pretty good.
If you want to destroy backgrounds regardless of distance to subject, than a Contax 645 + 80mm f/2 will do the trick
