unpopular
I have an idea for a project, to take found objects and print them on a white background at actual size. I was wondering if anyone had any ideas about how to do this without measuring the object?
The equipment I plan to use is either a 75mm or 50mm lens mounted on bellows. I also know that there is a formula for calculating magnification (Lens Magnification and Depth of Field Calculator) . But i'm a bit confused as to how to put the two together.
