fjrabon
- Joined
- Nov 3, 2011
- Messages
- 3,644
- Reaction score
- 757
- Location
- Atlanta, GA, USA
- Can others edit my Photos
- Photos OK to edit
A little thing that is about the size of a small cheeseburger, pops on and off the end of your lens is cumbersome? With an expo disc it takes me under a minute to white balance. Also, you just point your camera at the light source that will be hitting your subject? Not sure how that's particularly difficult?
With a grey card you either have to do stuff in post, after having your subject hold the card, or you have to make the card take up the full frame, which I've always found to lead to slight inaccuracies, since you're not shooting from the same angle you normally would.
I can understand not wanting to pay the money for an expodisc, but saying its 'cumbersome' is just unfathomable to me. Pros love expodiscs precisely because of how fast and non-cumbersome they are.
I used grey cards forever, until I started using an expo disc every day for work. After using an expodisc consistently on a day to day basis, it was hard to go back to grey cards, so I finally just bit the bullet and paid the money for my own personal one.
If the Expodisc works for you that's fine...I'm not saying that it doesn't work. It's just that in my personal opinion I think it's more cumbersome to use than a card.
I look at the usability issue from the perspective of walking around, say, a large museum, where every room has different lighting. I want to set a custom white balance quickly without having to unzip a pocket on my bag (or sometimes I don't even have my bag.) I guess I could carry an Expodisc in a front pocket...which it would have to share with a phone or keys. But carrying a card in the back pocket is easier than in a bag, and more comfortable than a front pocket.
I use a gray card that's 4"x6" and only 3mm thick...it fits in my back pocket and I don't even feel it back there. As I have a Nikon, it literally takes me less than 10 seconds to set a custom white balance. I hold the WB button for two seconds to initiate the WB procedure, whip out the card from my back pocket, face it towards the light (or if there are two light sources, held to catch both,) and then frame the card and press the shutter. I don't even look through the camera...I just put the lens directly on the card, careful not to block the light. Then the card goes back in my pocket and I'm ready to shoot. It's fast, easy, indestructible, and works every time. The card was only 15 bucks and can be "refreshed" with sandpaper should it get dirty.
I'm sure the Expodisc works well...I simply don't see what advantage I get by spending 5 times as much, and always having to point in some other direction into the light source to set my white balance. And what do you do with two light sources? If you don't point the Expodisc directly at the source, the color from the area that you are pointing at may influence the white balance setting. I don't have that problem with a card. It's for these reasons that I never recommend the Expodisc. But like I said...it's just a personal evaluation...one person's opinion.
Hmm, I've just never found this method of WB'ing to be particularly accurate for me, often not even as accurate as just using auto WB. But maybe you're just better at it than me. I cant think of a single time my expo disc has ever been noticeably off. just my opinion.
